Username Post: rough idle and driving        (Topic#339337)
freeway
freeway
Loc: NV ,Reno Tahoe area
Reg: 09-01-03
09-23-16 07:16 AM - Post#2652848
had 75 stingray transported across country, went to start and in was running rough. when idling sounds fine but driving sounds like missing. vcould it be filter in gas line or plugs Came from NV to PA
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-29-16 03:32 PM - Post#2654053
    In response to freeway
A LOT OF TIMES THE BOOT DRAIN AROUND THE GAS TANK FILL CLOGS & WATER CAN ENTER THE TANK.INSECT'S LIKE TO BUILD NESTS IN THE DRAIN TUBE ALSO. FOR A MISS CHECK THE CAP,WIRES PLUGS ETC.Q-JET'S HAVE THEM LITTLE BRASS LOOKING GAS FILTERS IN THE CARB ALSO.BE CAREFUL NOT TO STRIP THE BIG FITTING PUTTING IT BACK INTO THE CARB & DONT OVER TIGHTEN.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Mercedes
Reg: 07-09-18
07-15-18 12:10 PM - Post#2740055
I'm afraid that there is not enough information to even start to diagnose your problem. You could have any of a dozen or more issues causing the misfire.
Execution time: 0.204 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:56 AM
