Username Post: Serpentine belt system        (Topic#339291)
grs
Reg: 07-04-14
09-21-16 10:27 AM - Post#2652530
I am putting a serpentine belt system on a 350 chevy engine. It will hooker headers. I can't put the braces on the engine because of the headers, and the Edlebrock intake. Will this cause problems?
DECEASED
09-22-16 03:08 PM - Post#2652726
    In response to grs
By "braces", do you mean the mounting brackets for the various components? If yes, how do you expect the affected components to remain in place?
grs
Reg: 07-04-14
09-23-16 12:35 PM - Post#2652900
No I am not talking about the brackets. There are braces that go to the intake to the AC unit. I think they stop the AC and ALT from vibrating and breaking the brackets. I am not sure tho.
DECEASED
09-25-16 02:47 PM - Post#2653235
    In response to grs
These things have problems enough when they are installed with all the parts they are supposed to have. Trying to get by without the braces is just asking for trouble.
If the braces furnished with the components can't be used, I suggest that you fab custom braces which can be attached to existing bolts or holes on the intake manifold, thermostat housing, water pump, or head. You could also check first with whoever supplied the serpentine system, but don't hold out too much hope.
grs
Reg: 07-04-14
09-26-16 07:29 PM - Post#2653484
Thanks everyone. I decided to buy a serpentine belt system from alangrovecomponents.com.
Execution time: 0.138 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:35 PM
