Username Post: 454 TBI vs 350 TBI, similar component?        (Topic#338950)
1987_chevy_
Reg: 09-02-16
09-09-16 02:11 PM - Post#2650386
So as of right now I am building a 383 stroker and planning on running the TBI system! I have bought a 454 TBI that I plan on using. The only problem is the the piece that holds the injector pods into place is cracked. Someone installed a injector spacer and must have tighten it to much and cracked it! I have a 350 TBI also. Could I just take the injector pod off the 350 TBI and swap it onto the 454 TBI also switching everything inside over (spring and injectors)? Are the injector pods on a 350 TBI the same as a 454 TBI?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-09-16 06:02 PM - Post#2650421
    In response to 1987_chevy_
The actual injectors, No
1987_chevy_
Reg: 09-02-16
09-09-16 06:33 PM - Post#2650430
    In response to junkman104
The injectors aren't the same but is everything else?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-11-16 04:00 AM - Post#2650594
If it the same year-same style yes. Some have different throttle position and idle air controls There are also different throttle bodys based on transmission type.
Execution time: 1.231 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:06 PM
