Username Post: 305 engine problem        (Topic#338817)
jammons
Loc: Pueblo, Colorado
Reg: 08-06-15
09-04-16 11:59 AM - Post#2649401
Okay I've rebuilt 10 chevy engines, no brag just let you know have done this before. I have a 305 engine that will run and idle and move the car perfectly. and then it will make a clanging noise and when I pull the valve covers it will have driven the pushrod thru the lifter. The first time I pulled the heads to make sure nothing was in the cylinder, nothing there. This has happened 3 times now.the first time was #6 exhaust, the second time was #5 intake. I haven't pulled the valve covers yet for the third time. When I got the engine #3 journal had been spun so I put a new crank in it and redid the heads. All valves, pushrods, lifters, springs and cam were in good shape. The question now is what do I do Now???
jammons
Reg: 08-06-15
09-05-16 07:20 AM - Post#2649550
    In response to jammons
back up!!! I meant to say rocker arms instead of lifters. my mistake. so sorry.....Jim
09-05-16 01:27 PM - Post#2649629
If the deck and heads have been machined, the pushrods could be too long, especially with a higher lift cam.
Execution time: 0.226 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:27 PM
