Username Post: MoPar 8 3/4" rear end        (Topic#338721)
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
08-31-16 09:44 AM - Post#2648819
To be up front I bought a MoPar rear end for my 57 but it is too short by an inch that I was told can not be added on safely.
At 55" (axle) flange to flange i was thinking it would fit a Chevy II. Would it? The spring perches haven't been touched.
I want to sell it because I've already drilled and filled the axles (Moser) bought the desireable green bearings, new backing plates, brakes, drums etc. It also came with a posi and 30 or 31 spline axles, the big u joint, etc. but I don't want to offer it up if it won't fit.
Thanks.
It's all good. Mostly
DECEASED
08-31-16 01:27 PM - Post#2648863
    In response to 4dr 57
As I recall, a stock 1st gen Chevy II rear is about 57" over the drums, so the rear will be a better fit there than in your 57. I have no clue about the spring spacing. You will just have to find one and measure it.
The Mopar 8-3/4" is a good rear, and with all the work and $ you have put into it so far, it would be a shame to turn it loose. Would you consider a spring relocation on your 57? A lot of rodders do this so they can run wide tires. Wheels with less backspacing will get your tires centered.
To get more info you could try asking on the 55-57 modified forum.
4dr 57
4dr 57
Reg: 11-10-04
08-31-16 03:31 PM - Post#2648891
Thanks for the measurements Ray
Sounds as though I picked the right car. All it would take to fit the II is narrowing the housing and axles (the axles are not tapered so it would be a straight, shorten the axles period,) and resetting the perches. Much simplier of a fit for this car then a 57. Somebody's going to get lucky as I just want to let it go. Haven't found a place to list it yet. Craigslist? Here?
DECEASED
08-31-16 09:19 PM - Post#2648949
Why would you want to narrow the Mopar rear? If I am understanding your measurement correctly (55" over the shaft flanges), it is already 2" narrower than a stock Chevy II rear.
I would suggest listing it on both the Chevy II and the 55-57 classifieds. As I said earlier, some tri-five rodders want a narrow rear so they can run wider tires.
4dr 57
4dr 57
Reg: 11-10-04
09-03-16 05:32 AM - Post#2649241
Thanks Ray, yes I think I understand what you are saying.
The 55" measurement is over the axle flange, not the drums. The short side/right side measurement is approx. 27 or 28" from the axle flange to the center of the housing, if I remember right, making the centering of the pinion in the Chevy II very simple. Easy in fact because one would only have to shorten one side of the housing and one axle.
And as I said before, the axle is not tapered so it is simply a matter of shortening the axle for this application. Oh, and resetting the perches of course.
DECEASED
09-03-16 06:31 PM - Post#2649309
Ahhh, I was misunderstanding you. Now I believe you are saying the measurement is 55" over the HOUSING flanges. I was confused because a lot of people on here say "axle" when what they really mean is "shaft". If you did mean over the shaft flanges, the difference between that and over the drums would be no more than about 1/4" because the drum webs are only about 1/8" thick at most.
Assuming stock Chevrolet backing plate and drum measurements, I would estimate the overall width at about 62", which is about 2" wider than a stock tri-five rear and about 5" wider than a 1st gen Chevy II rear. This could differ somewhat if you are using Mopar backing plates and drums redrilled with the GM 5 on 4-3/4" bolt pattern.
4dr 57
4dr 57
Reg: 11-10-04
09-04-16 04:19 PM - Post#2649448
That's probably about right. It makes the off set a problem under a Tri5 because one can't add inches. Atleast that's what Moser told me.
What would happen under a Deuce is the axle would be shifted to the left in order to center the pinion, leaving a couple inches hanging out the right side. This is where is would be shortened. Nice and clean.
I was disappointed when it didn't work this way for the 57 but that's the way it goes. But under a II, man that should be sweet!
I'd like to be absolutely sure. If I knew what the short side measurement on a Chevy II and/or a Nova is, I would be
I'd have to then remeasure the housing, off the backing plate? to make sure but I think it will work out well.
Maybe if somebody besides us reads this Post they will chime in and I can get on with it.
Member #409
09-04-16 05:48 PM - Post#2649466
My head is spinning on the discussion of what you're measuring and where.
A 62-67 Chevy II axle is 57"+ across the wheel mounting surfaces.
55" on the housing is too wide for a Chevy II, and 55" on the wheel mounting surfaces is too narrow without moving the springs.
Actually I think the same holds true for a 55-57 Chevy, but the 55-57 is 60.25" wide across the wheel mounting surfaces.
4dr 57
4dr 57
Reg: 11-10-04
09-05-16 05:19 AM - Post#2649531
    In response to Rick_L
There have not been any measurements given except of the axle housing itself. Suggest you reread the post. Regards.
Member #409
09-05-16 09:40 AM - Post#2649589
If 55" is the width of the axle housing, it's too wide for a 62-67 Chevy II/Nova.
4dr 57
4dr 57
Reg: 11-10-04
09-05-16 12:58 PM - Post#2649621
Yes, that's right. I suggest you reread the posts, slower. When you get to the part where I talk about moving the housing to the left in order to center the pinion, then only having to shorten the right side of the housing and the axle, let me know if you think this would work, as I do.
I think it would be an easy way to a great upgrade. I can only wish it would have worked like this under my 57.
The e-brake even looks like it will work w/o any changes too. Thanks
jxnslotcar
jxnslotcar
Loc: Jackson,Michigan 49202
Reg: 04-17-11
11-14-16 11:52 AM - Post#2661532
I never saw what you would take for the rear diff? For what I am putting together I would need to narrow both sides.
1965 Mailbu 2dr post (old drag car)
1964 Chevelle SS-looking for a frame
1958 Chevy Biscayne 4dr hardtop (4 sale),72 MGB (4 sale)
1963 Chevy II 2dr hardtop (on the rotisserie)
65 Olds Jetstar Convertible (4 sale),63 Pont Grand Prix 2dr (4sale)
56sedandelivery
Deceased Member RIP
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-03-17 11:59 AM - Post#2684777
    In response to jxnslotcar
There must be a demand for it with the MOPAR guys. Those are the guys I'd be targeting. I have a friend that deals in Tri-Five Chevrolet cars AND parts. Years ago, he had a 56 Bel Air 2 door sedan, with a 454/TH400 out of a truck, and a "Pontiac" rear end. I looked under it one day, and thought that's a 56 and older Pontiac rear end, until I saw the pinion snubber bosses on the front of the third member. MOPAR! He had no idea what the rear end originally came under; it was in the car when he bought it. He eventually sold the car, the rust bucket it was. The 8 3/4" MOPAR rear ends are pretty strong. After the 57-64 Olds/Pont rears fell out of favor with the Fuel Funny's and Dragsters, they all started to use the 8 3/4" MOPAR or Ford 9"; that was before the aftermarket, modular rear ends came out. I'd target the MOPAR guys. I am Butch/56sedandelivery.
Execution time: 0.104 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:35 AM
