Username Post: Nomad fuel filler neck leaks        (Topic#338468)
1carguy
Reg: 11-30-08
08-21-16 01:23 PM - Post#2646913
I've been smelling gas recently in my '55 Nomad. While filling the tank today, I noticed that the fuel filler neck was wobbling around. I found that the neck is very loose in the fuel tank and is dripping gas. The neck in the tank seems to be larger than the filler neck but I can't tell what seals the tube when pushed into the tank neck. Is there an o-ring or something. I don't know whether this is stock or if someone has changed something. It doesn't look like a good way to connect the filler to the tank. Anyone know?
Site Ambassador
08-21-16 06:57 PM - Post#2646961
    In response to 1carguy
Yes there is an o-ring that is supposed to seal the filler neck to the tank inlet.
1957 Cameo Carrier
1carguy
Reg: 11-30-08
08-21-16 07:24 PM - Post#2646968
    In response to wagonman100
Thanks for the confirmation - I took it apart this afternoon and found a very old, flattened out 0-ring that appeared to be original. I shopped all over town and no one had a replacement so I packed it with some Permatex sealant and put it back together until I can order the right o-ring. I'm going on a hot rod tour tomorrow with the Goodguys and I think it will be fine, especially if I don't fill the tank.
johnminton
Reg: 04-11-18
10-07-18 11:26 AM - Post#2748056
Echlers sells them.
Execution time: 0.148 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:25 PM
