Username Post: 1985 Cavalier 2.8L FI Type 10 Convertible        (Topic#338237)
AleDukes
Reg: 08-12-16
08-12-16 06:01 AM - Post#2645284
No power to Ignition Switch. No Fuel Pump noise, no Solenoid click, no IP lights when turned to Start. Any ideas? It did turn over previously, stopped turning over when jumping a bad battery. Got a new battery and will not turn over.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
08-13-16 05:05 PM - Post#2645526
    In response to AleDukes
Fuseable link on starter solenoid would be my first guess.
AleDukes
Reg: 08-12-16
08-30-16 06:13 AM - Post#2648605
    In response to junkman104
Fusible Link appears good on Solenoid. Power at the Starter. Does Power for Ignition Switch route through the connection on the starter (Positive Cable) or sent to the switch another way?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
08-31-16 03:15 PM - Post#2648901
Red wire at the ignition switch should be hot at all times.
AleDukes
Reg: 08-12-16
08-31-16 04:19 PM - Post#2648913
OK, but I'm trying to figure out why there is no power there.I need to find a schematic of the wiring showing where the power comes from.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-01-16 03:47 PM - Post#2649040
On the starter main terminal.
http://www.revbase.com/BBBMotor/Wd/DownloadP df?id=26154
AleDukes
Reg: 08-12-16
09-02-16 04:26 AM - Post#2649107
So, Ignition Switch Power comes from Starter Terminal? I'm not good figuring electrical stuff.
Edited by AleDukes on 09-02-16 04:28 AM. Reason for edit: No reason given.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-02-16 02:13 PM - Post#2649187
Fuse-able link B in the schematic is the power supply for the ignition switch.
Execution time: 0.095 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:57 PM
