Username Post: 96 Camaro RS Windshield Wiper Motor Issue        (Topic#338064)
Bluesteel6900
Reg: 08-05-16
08-05-16 03:39 PM - Post#2643947
I changed the windshield wiper motor because the old motor would not run. All I heard is clicks from the motor and no movement. I bought a new motor assembly from Autozone and followed the instructions for installation, also read the Clymer manual. With power turned on, I get no movement in the delay settings, and I get some movement in the normal mode. It sweeps either fully once or partially, and then quits moving with the clicking noise re-appearing. Am I looking at a control stick/turn indicator stick change? Bill
Bluesteel6900
Reg: 08-05-16
08-06-16 01:42 PM - Post#2644058
    In response to Bluesteel6900
I guess no-one has an idea on what the problem might be? *sigh*
77chevy
77chevy
Loc: trusting earth to a boys ...
Reg: 01-26-01
08-08-16 12:47 PM - Post#2644481
whats the wireing like on yours? mines an elctrical mess. id say check the plug(wiggle) and connections with wipers on. maybe even try jumper wires from plug to connector. i had to replace bad plugs before. oh so may electrical gremlins I have. also seen some of the wiper assemblys hard to move almost rusted.
Bluesteel6900
Reg: 08-05-16
08-08-16 09:25 PM - Post#2644646
    In response to 77chevy
Wiring is clean. I'll be checking the switch assy next with an ohm meter and see if there are any shorts or issues.
77chevy
77chevy
Reg: 01-26-01
08-09-16 05:24 AM - Post#2644694
did you do the board, should be on the wiper motor? i had a buddy rebuild my column to take out slop from tilt mech going bad. he said the wiper switch inside the column isnt bad, but thats from a guy whos done a few.
Bluesteel6900
Reg: 08-05-16
08-12-16 03:44 PM - Post#2645342
Yes. The new motor came with the new board attached.It is in the real of possibilities that I got a new motor & board with the same problem, but doubtful. I'll be checking the switch with a meter tomorrow.
Bluesteel6900
Reg: 08-05-16
08-19-16 07:53 PM - Post#2646694
Found the connector intermittent going into the motor. Did what I could for now, so at least the wipers work on the high setting. Next, a new connector.
Execution time: 0.168 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:20 PM
