Username Post: Very loud noise when blower motor is on high        (Topic#337780)
Turbo2
Reg: 07-26-16
07-26-16 12:56 PM - Post#2641884
I have a 1990 Celebrity Eurosport Wagon and the blower motor is very loud on high speed only. I have tightened all the bolts but it is still loud. It seems as though the blending doors are not closing completely and also change depending if I am stopped at idle or moving at speed. Does this mean I have to tear out the whole dash to fix this?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
07-27-16 04:18 PM - Post#2642091
    In response to Turbo2
Take the blower motor out and look for evidence of vermin. AKA insulation and turds.
Turbo2
Reg: 07-26-16
07-27-16 05:11 PM - Post#2642099
    In response to junkman104
I took it partially out (to take it all the way out I would have to remove at least the alternator and maybe more) and didn't see anything in the fan wheel itself. Would there be debris anywhere else?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
07-27-16 05:29 PM - Post#2642103
Might be but debris and unbalance makes a heck of a racket and vibration.
Turbo2
Reg: 07-26-16
07-31-16 11:11 AM - Post#2642795
Well, I tried to take a look into the blower system to see if there is a mouse nest anywhere (or any other problems)and it was a disaster. I tried taking the dash plate off around the radio and the cigarette lighter would not release. It supposedly has a nut on the backside holding it in but nothing is there and nothing unscrews so I couldn't continue. I tried to get the passenger side dash off and instead of clips to hold it in place, it's screwed in from the backside and I could only get to the bottom 2 through the glovebox so I had to give up on that. I tried to remove the heater core to see if I could see anything from there and after taking all the plastic out of the way only 1 bolt is 7mm like all the rest of the bolts for the dash, the other 3 are not metric or standard, but some other unknown size (british perhaps?) so the whole day was a waste of time. I can only imagine how much a shop would charge for working on a nightmare like this.
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:34 AM
