 Page 2 of 2 <12
Username Post: Keith's 65 Impala Upgrade        (Topic#337580)
kwhizz
kwhizz
Reg: 01-01-07
08-15-16 11:12 PM - Post#2645945
    In response to 66impgirl
Got all the A/C ductwork installed along with the vents.......the gas pedal also got installed......Ialso got started on installing the fan relays.......just need to get the wiring for the Trinary switch and a couple of A/C wires hooked up....then put the dash back in and get the neutral safety switch adjusted.......my one issue I have is a very slight gas leak from a fitting on the top of the tank.....Darn......need to pull the tank down and see what's going on there.......
kwhizz
kwhizz
Reg: 01-01-07
08-16-16 05:29 PM - Post#2646092
    In response to kwhizz
Got the Trinary switch and all the A/C wiring finished today........then I moved on to the Fan Relay's.....That open area next to the Battery sure filled up fast......LOL........Done !!!........one of those stupid little things that was a little problem was the Brake Booster Vacuum line......the Power Booster had a hole size larger than most and I couldn't find a Check Valve to fit with the new sizes needed.....so....I made up a adapter and blended the large and small hoses together........Started to put the dash assy in.......I'll finish that up tomorrow and then the last thing (hopefully) to do is to drop the Gas Tank and reseal the pipe thread fittings that leak one drop at a time......Darn.......Gotta fix it....
kwhizz
kwhizz
Reg: 01-01-07
08-17-16 04:47 PM - Post#2646287
Pulled the gas tank out today and got the leak fixed (Teflon Tape instead of pipe joint compound......Lesson Learned-AGAIN !!!!!)......Then I finished the Dash install......Started programming the Dakota Digital system and got a few issues........I'll call them tomorrow and their Tech Support will walk me thru the programming sequence........LOL.......Also.......the neutral safety switch is fighting back.........waiting for a call from Shiftworks to resolve that issue.....
Here's a pic of the dash.........(engine off , key on, lights on)Check engine light is on because the O2 Sensors aren't installed yet..........Going for the Exhaust on Monday........
evhfan2000
evhfan2000
Loc: Portland, OR.
Reg: 10-17-04
08-17-16 07:44 PM - Post#2646317
As always....NICE WORK! Someday, I'll make the move to an LS or BB.
Dean
65 Impala Sport Coupe
99 CK2500 4x4 7.4L Crew
03 CK1500 4x4 5.3L Sub
02 CR250R
kwhizz
kwhizz
Reg: 01-01-07
08-19-16 05:12 PM - Post#2646665
    In response to evhfan2000
Beater ....................
Had to wash the Garage floor to clean up all the Dust that fell off the Beater
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
08-20-16 06:21 AM - Post#2646720
We should all have "beaters" like that.
Nice work as usual Ken.
Dan
leon phelps
leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
08-22-16 05:18 AM - Post#2647000
I hate to ask, but what would one of your swaps cost?
1963SBHD
1963SBHD
Loc: south carolina
Reg: 09-01-11
08-22-16 01:16 PM - Post#2647046
    In response to leon phelps
Would ballpark 18-20 grand ??
Ron Shaw
Reg: 01-01-13
08-22-16 01:49 PM - Post#2647049
Is he keeping that ride height?
Did it sit lower before the swap?
kwhizz
kwhizz
Reg: 01-01-07
08-22-16 05:19 PM - Post#2647087
    In response to Ron Shaw
The Exhaust system just needs some finish welding and it is done........Going to Ricchio's tomorrow for A/C charging.......then back home to Keith's........
leon phelps
leon phelps
Reg: 06-04-05
08-22-16 06:48 PM - Post#2647101
ls7 458 pounds
small block 500-600.
its gonna sit higher.
bjornas
Reg: 05-30-14
08-23-16 01:52 AM - Post#2647144
This is very nice and clean upgrade!!
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
08-23-16 04:26 PM - Post#2647255
    In response to 1963SBHD
If going with brand new, off-the-shelf, I could see it get close to that. Auto recycler acquired would be MUCH less for 5.3L and matching 2wd auto trans WITH wiring harness and CPU. CPU will likely need re-flashing after harness has been modified to exclude features that aren't needed anymore. The newer the engine and trans (lower milage), the more you will pay.
I can get a 50,000km 5.3L (truck application) from my pals at a local yard for about $1,500.00 (Canadian).
Nitrous is like a hot girl with STD's…You know you wanna hit it, but you’re afraid of the consequences!
1965 Biscayne 2 Door Post: 350,PG,373-posi,C3-DB, PS,PB.
1970 Chevelle Malibu: 53 on 753.
Brian Daniel McClure: 1970-2015. R.I.P. Brother.
1963SBHD
1963SBHD
Loc: south carolina
Reg: 09-01-11
08-23-16 04:59 PM - Post#2647259
    In response to BowtieGent
Yeah think this guy had the dollars..but health issues too. His mates took the old stuff out and kwizz got the restored clean slate to work with. Man I love his expertise..would pay him to apprentice.watch him build a few...and gofast too he is great at metal work..too many ideas..not enough time. Got a local guy who does this stuff..might just give him a call. Peace brother and have a blessed one.
Michael J.
leon phelps
leon phelps
Reg: 06-04-05
08-23-16 06:02 PM - Post#2647275
we werent asking for the DIY piece it apart price, the GM crate engine and other stuff from the different specialty manufacturers price.
my swap still cost me close to 10k doing it the cheap way with a use 5.7 ls1. I skimped most reasonable ways.
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
08-23-16 08:10 PM - Post#2647303
I've been wondering, and I'm not the only one based on the comments on the video series, how much this restoration cost?
https://www.youtube.com/watch?v=QRd5P9Se_Ts
Ryan
Build date Dec. 21 '64 Oshawa
kwhizz
kwhizz
Reg: 01-01-07
08-24-16 06:05 AM - Post#2647366
    In response to Oshawa65SS
with the A/C and everything it was probably in the 15 K range
kwhizz
kwhizz
Reg: 01-01-07
08-24-16 06:06 AM - Post#2647367
Sorry I couldn't post yesterday.....had some computer issues.........Anyhow......The Exhaust system got finished and the A/C system got charged.......I was so excited to get that "Pile" out of the Garage that I forgot to take a bunch of pictures on the delivery of the car to Keith.....I had Keith keep the Hood at his house so I wouldn't have to worry about scratching it while working on the car, so.....I drove it back to his house without the hood..........(Lot's of honks from the truck drivers along the way as they could see what was powering the car).......LOL..... Gary followed me to give me a ride home.........any how.....we met Keith, Bob and Keith's wife Kathy at the house and delivered the car.......Explained a lot of the features to Keith that are now built into his "Heap".......LOL......Just glad to be able to help out a fellow Car Guy............
Here's a short Video of the drive to Keith's House
http://vid13.photobucket.com/albums/a251/kwhizz/65 ...
Keith, Kathy, and Bob
Gary with the car
All Done......Now I can go home and get the Garage cleaned up.......LOL
kwhizz
kwhizz
Reg: 01-01-07
05-07-17 10:30 AM - Post#2690044
Now that the car season has rolled around again..........Keith sent some pictures of his car after final assembly..........interior is in and completed and he installed a Hydro-Boost also.....Me thinks he enjoys the car better with the upgraded drivetrain.........Maybe Keith will respond with his thoughts about the before and after...........LOL.......Here are the Pictures
ls1wagon
Reg: 11-16-18
11-16-18 09:33 PM - Post#2751576
What Headers are those?
kwhizz
kwhizz
Reg: 01-01-07
11-17-18 03:55 PM - Post#2751634
    In response to ls1wagon
https://www.ebay.com/itm/Stainless-Caprice -LS1-LS6...
The headers are made and fit perfectly...….. I would definitely get U.S. made header bolts as these are very low grade and it's very possible to twist the heads off without any effort and it's a pain to get the broken part out...…. Ask me how I know....LOL
Ken
Edited by kwhizz on 11-17-18 04:00 PM. Reason for edit: No reason given.
Shmedly
Shmedly
Loc: Las Vegas
Reg: 03-12-15
08-31-19 11:45 AM - Post#2774572
Is the 4l/70 much larger then the 4l/60e? Did the tunnel need any work to get it to fit?
Double Aught
Loc: SW America
Reg: 09-28-11
08-31-19 07:58 PM - Post#2774594
  • kwhizz Said:
Is this plate specific to that year console? I can't find one for my 68 console.
kwhizz
kwhizz
Reg: 01-01-07
09-01-19 05:10 AM - Post#2774608
    In response to Shmedly
Same size...… Just some slight hammer massaging req'd…… No problem
kwhizz
kwhizz
Reg: 01-01-07
09-01-19 05:11 AM - Post#2774609
    In response to Double Aught
  • Double Aught Said:
Check with Shiftworks.com
Double Aught
Loc: SW America
Reg: 09-28-11
09-01-19 11:46 AM - Post#2774624
Yah, I bought my shifter from them years ago and they didn't have one then and they still don't. I have also tried OPG and ordered one for a Chevelle console, but it was too narrow. Looks like I'll have to live with it.
Edited by Double Aught on 09-01-19 11:47 AM. Reason for edit: No reason given.
 Page 2 of 2 <12
Execution time: 0.145 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:47 AM
