Username Post: 1954 Chevy Deluxe 210 Club Coupe        (Topic#336989)
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
06-26-16 04:54 PM - Post#2636218
Hey guys, I wanted to introduce my project to all of you. After I liked the customs of the 40´s and 50´s more and more the more I got into it, I was watching around in the internet and found there a 1954 Chevy Deluxe 210 Club Coupe only 3 hours away from me over here in Austria (formally it’s from Frenso, CA).
The next day I jumped in my car, drove down to have a look at it and found it was in better condition as I expected so I bought it.
Attachment: DSC_0409__Medium_.JPG (258.72 KB) 111 View(s)
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
06-27-16 12:02 PM - Post#2636383
    In response to 54er210
The plan was simple. I wanted to build a real traditional looking custom like it could have been built back in the 50´s. An airride suspension to get it real low, some fender skirts for the back, some additional classic trim parts and finally the roof and the sun visor should be painted in original ivory.
The paint of the body should stay as it is, also some smaller scratches in the body an on the trim will be kept, only the dents that are too big will be repaired. I would like to keep these “traces of the past” because you should see that this is a car that was driven all the time and not a trailer queen. Adding some pinstripes, maybe a swamp cooler and the car should be perfect to cruise around over here.
After I had the car in my workshop, I started demounting it.
At the same time I started to order parts for the suspension (because I wanted to keep the original front end for the airride suspension), dropped uprights from fatman and slambags.
I started to draw, construct and machine the first parts to adjust the frame, c-notch it in the rear and adjusting the axles.
Next step was c-notching the frame.
To mend my mistake with the four link (no, it is not possible to build a four link with the original closed driveshaft ) I bought a gearbox out of a 56 bel air and a rear axle of a 1995 Chevy S10.
Next was the front axle. And this should prove to be the most difficult subject on the build so far ...
When the front axle was finished, dajusting the wishbones was next
At least manufacturing the bag mountings
Front axle is now done.
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
06-27-16 12:15 PM - Post#2636387
In between I did some parts to get closer to the look I want the car to get.
Adding some additional grill teeth.
Then I did the rims, painted them an mounted some new tires
To lift my mood a bit after working for weeks, I wanted to see how low the car would get, do I completed the chassis as far as necessary to see the stance. What should I say, I love it
After demounting it again, I added the rear bag mountings, the crossbeam with the shock mountings and all the mountings on the rear axle.
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
06-27-16 01:40 PM - Post#2636406
The second part, the body, started next.
After we got it on the car lift, we cut out all the holes that are necessary, only two small ones because of rust (the floor panels on the driver and the passanger side), and a few bigger ones to fit the body back on the customised frame.
All the sheet metal parts are cut out of this big panel and handmade by my father. His skills in doing this work are great
Afterwards we mounted the body on the frame to see how all fits together.
And this looks great, I love it
Next step, customise the fender skits.
I don´t like how the original skirts look like, they are too short. So we decided to make them lonkger and give the car a smooth flowing bodyline
Thats it from me for the moment.
If there is some further progress I´ll show you the pichtures
With best regards
Stefan
06-27-16 07:45 PM - Post#2636487
Looks like good progress. When did you start on this build?
29-41, 42-48, 49-54 Moderator
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
06-28-16 10:50 AM - Post#2636578
Hey,
thanks.
I started the build last year in september.
Because the original chassis isn't the easiest to get an airride in, some parts took me a bit longer ...
But that's ok for me and I keep on building
Fitzback
Fitzback
Loc: St-Hyacinthe, Qc. Can.
Reg: 01-23-08
06-29-16 10:03 PM - Post#2636861
good work! keep posting!!
Fitz.
La vie est belle! 1953 Pontiac Pathfinder deLuxe 2 doors sedan + Victory Vision tour
Fitz
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
07-31-16 12:52 PM - Post#2642816
Hi together,
it´s been a while since I was posting here, but I was still busy.
I completed the frame, did last weldings and adjustments and then gave it away for sandblasting. Also the front axle and some smaller parts had gone there.
Then I finished the body. Welded in all the sheet metall, seald all the welding and painted all. The rest of the floor which was not touched by the sheet metal work got a coating with some "conservation oils".
Afterwards we painted the roof and the sun visor white, I think this is looking very well
Also the back side of the car and the fenderskirts got prepaired for paint.
At least there was the rebuilding of the fresh air intake because it had some bad rust on it.
Next step is to finish the rear axle, then get some new seals into the engine and prepair everything for reasembling when i get back the frame.
So far from me
greetings
Stefan
08-02-16 05:52 AM - Post#2643176
Looking great!!!!!
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
08-02-16 12:57 PM - Post#2643252
    In response to Bob_Hayden
Thank you!
I am pleased that you like my build and I try to do it as good as the time that I have for this project allowes me to.
Stefan
Pmullins61
Pmullins61
Loc: Frankfurt, Germany
Reg: 04-17-16
08-03-16 12:23 PM - Post#2643511
Love the look did you fit the air ride
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
08-03-16 01:31 PM - Post#2643527
    In response to Pmullins61
Hey,
I am not sure what you are meaning with "did you fit the airride".
Greetings
Stefan
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
10-02-16 05:32 AM - Post#2654438
Hey guys,
it's been a while since I was posting the last time here, but that doesn't mean I wasn't working on my 54
The first thing was to finish the body. We flattened the rear side wall because there had been a big dent in it and repainted it. Also the finished skirts got some paint.
Next I got back all my parts from sandblasting. But the qualitiy of the primer was bad, so I had to sand all the parts per had a second time, that took me hours
Afterwards, all the parts got some matte black paint.
Next step, let's start reassembly. First the rear end. The axle also got new seals and new outer wheel bearings. Also the complete rear brake setup was done new and also new shoks were added. The rest seemed to be in very good condition.
After completing the rear end, obviously I had to test the airbags -> YESS it's alive
https://player.vimeo.com/video/184043125?title =0&a...
Then I started compleeting the front end. I installed a new king pin set. The brakes seemed to be relativly new, so I didn't change them, just cleaned everything and put it together again.
Then also had to test the airbags at the front, they are also working fine.
https://player.vimeo.com/video/184039387?title =0&a...
Next I thougt I'll overhaul the main brake cylinder ... Unfortunately I've got the wrong overhaul kit (1" instead of 7/8" diameter) and also the honing the cylinder didn't bring back a real fine surface inside the cylinder. So I decided to clean all the part, reassemble it and give it a try. If it will not work correct or is leaking, I'll install a complete new one.
At least I demounted the engine to change all the gaskets and check the inner parts of the engine. At a compression test I did when I got it last year, all 6 cylinders were great. After demounting the engine, I could see why. It seemed that it got overhauled not long ago. Surface of the cylinders is looking good, also all the other parts seemed to be ok.
So just installed all the new gaskets, and put it back together.
Some new paint on it and finished.
At first I thougth the paint i bougt would be nice, but when I finished it I didn't like it at all, so i grinded it down and repainted it, now I like it and it will be installed next week, hopefully.
With best regards
Stefan
10-02-16 11:33 AM - Post#2654486
Outstanding work. Looks good.
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
10-03-16 07:55 AM - Post#2654638
Thanks, I try to give my best at this build.
Regards
Stefan
chevyguy65
chevyguy65
Loc: New Berlin,WI
Reg: 08-24-09
10-05-16 05:53 AM - Post#2654977
Great Job!
"NEVER GIVE UP"
1949 4dr Fleetline
'06 Silverado z71
'16 Malibu
Pmullins61
Pmullins61
Reg: 04-17-16
10-11-16 12:19 AM - Post#2655978
Hi Stefan
Where did you purchase the Air ride here in Europe or imported from the US, I want to put it on my 1950 Fleetline
Regards
Paul
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
10-11-16 02:20 PM - Post#2656060
Hey Paul,
the bags I am using are from slam specialities in the USA (SS-6).
The whole air management system, the air tank and the compressors are from airride supplies in germany.
All the other parts to make it fit into the chevy are self made ...
With best regards
Stefan
Pmullins61
Pmullins61
Reg: 04-17-16
10-13-16 01:19 AM - Post#2656289
Stefan
Many thanks, how much did you need to fabricate yourself,
I am looking at all options, having a company do this for me or I have a guy that maintains the car for me, he certainly can do this or third option I bring it to you in Austria to do it for me)))
What was the budget to complete
Many thanks Paul
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
10-18-16 12:59 PM - Post#2657215
Hey guys,
another bussy week is over, but I made some greate sucess.
First of all I got the flywheel machined, now it's ok again. next was sandblasting and painting the right bellhousing for my gearbox (I was searching nearly a year for one ... )
Next step was installing some new seals on the gearbox. But as it comes, I completely demounted it, cleaned all the parts, and put it back again with all the new seals.
It seems to be in good shape, no big wear on the teeth, bearings seemed ok too. Only the bearing on the input shaft made some light noise. But I'll will do a complete overhaul when I have time and got all the spare parts, including the synchro clutch .
By the way, it seems that it is a saginaw 3 speed if I interpreted the stuff I read here right.
Next step, installing the new clutch set and then getting in the engine.
After that, the second part of the wedding was in line.
After the body was on the frame I had to check if all the metalwork on the body was done correctly. Seemed we worked good, everything fits, there is enough space in between.
Also had to try the custom made skirts, I like the look without this edge the original, short ones make.
At least I was calculating a bit and I decided I do have to change the rear axle gear ratio to get a bit lower rpm while driving long disances on the motorway. Think 3,07 should be all right.
Regards
Stefan
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
10-28-16 01:23 PM - Post#2658837
Hey guys,
I used the last few days to complete the front of the car and did a few other, smaller things.
Today I used the last sunrays of the autumn to get the car out of the garage to see how it looks like ...
I pretty much like it
Regards
Stefan
10-28-16 05:26 PM - Post#2658870
Looks good.
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
11-21-16 02:35 PM - Post#2662590
Hey guys,
made some more progress on my build.
After rollin back the car in my garage, i started further compleeting.
First step was rebuild all the brake lines or repectively make them completly new.
Next step was the exhaust manifold. I sanded down all the rust, milled down all the cast edges inside the manifold, repainted it, added new bimetal springs for the heating valve and reassembled it.
Next step was rebuilding the carbs. Both got cleaned and also got new gaskets.
Next step was building a new exhaust. I worked with 2" steel exhaust pipes. Worked out good, and I think it will work fine.
After adjusting all the parts, the exhaust got welded, ginded and painted and at least got covered with heat protection ribbon because it runs really close under the body ...
Last step was drafting the attachment of the airtank and the compressors and the control panel for the pressure gauges and all the control switches.
I think the control panel got a real classic look and will fit well under the dash.
With best regards
Stefan
11-21-16 09:36 PM - Post#2662663
Looking good.
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
01-10-17 03:14 PM - Post#2670474
Hey,
it's been a while since I was writing about the progress i made on my project.
First of all, i completed the engine, put on the carbs and all the lines for vacuum and fuel, filled oil and cooling fluid, built a new throotle linkage because the one I got with my manifold dind't fit at all and then fired it up. And she's running good
Next step was adjust the propeller shaft for the correct lenght. Now it is at a local shop for welding and balancing.
After that i went back to the trunk to complete the airride system. Fist I painted the air tank. Next was finishing the control panel and the assembly and sealing of the airride parts.
After cutting a new carpet for the trunk, i mounted all the airride stuff and did the wiring.
The battery and the valves will get covered with an old suitecase for a cleaner look in the trunk.
The inside carpet and compleeting is next. Also adapting the electrical wiring of the lights to Austrian standards and then the first big step of the project should be quite finished within the next weeks ...
With best regards
Stefan
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
04-26-17 11:26 AM - Post#2688344
Hey,
it's been a while since i did my last update here.
But it's been real busy the last months with completing the car, building a house, ...
But "the first stage" of my build on the chevy is done since february. And now with the weather turning to summer, I'll go crusing the season with this state of the car.
Leaving you with some pics I did a few weeks ago.
Regards from Austria,
Stefan
04-27-17 08:03 AM - Post#2688480
Enjoy your cruising.
Bel Air kiwi
DECEASED
Bel Air kiwi
Reg: 04-24-14
04-28-17 09:18 PM - Post#2688800
Hi Stefan, congratulations on a very successful build. Great work and good to have your Father helping. I really like what you have done with the fender skirts. The factory ones don't look like they belong to the car for most early Chevy's.
Cheers Kiwi
DECEASED
04-29-17 09:33 PM - Post#2688923
    In response to Bel Air kiwi
Not to complain, but in the pictures I am looking at, I don't see any fender skirts. May I correctly assume we are talking about the skirts which would normally fit in the rear wheel openings?
54er210
54er210
Loc: Upper Austria
Reg: 08-29-15
05-01-17 10:48 PM - Post#2689263
Hey kiwi,
thank you, I am delighted to read that my build and my style in building cars get's liked by other people too. Yess, the original shape of the scirts doesn't fit the body lines at all ... So I decided to customize them to follow the body lines and to make them look like the should have been there forever.
And yes, my father did great work on the sheet metal. I'll pass your post on my father, think he'll be happy also
@raycow: Yess, you are also all right. The scirts are not mounted on the last pictures I posted. They have to be customized a bit more because they hit the tire when i lift the airride completely and in the moment there isn't enough time to do this, but this will follow because the look with the scirts is amazing I think.
But if you look in Post#2636406 you may see how they look like.
Regards
Stefan
Execution time: 0.176 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 PM
