Username Post: fusible link in Monte starter circuit?        (Topic#336961)
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
06-25-16 06:24 PM - Post#2636063
I just installed an engine in a '71 Monte Carlo. The starter circuit wires need replacement. I can't find anything on the internet, and I need the car running by Monday. Can you gents tell me if a fuse or fusible link is needed for the switch terminal on the solenoid? Thanks.
DECEASED
06-25-16 10:43 PM - Post#2636089
    In response to aftershock222
There should be no fuse or fusible link in the wire connected to the "S" terminal on the solenoid.
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
06-25-16 11:41 PM - Post#2636095
Thank you, sir, I'll finish the wiring first thing in the morning.
Execution time: 0.127 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 PM
