Username Post: engine runs rough and stops        (Topic#335396)
54BelairSC
Loc: Central Florida
Reg: 07-12-15
05-01-16 07:00 PM - Post#2625598
My C6 started to run rough and the display said reduced engine power. Then it stopped and the display said service fuel system. So far the dealer has replaced the alternator and battery. The problem still existed. They also said they found a bad ground and reprogramed the throttle body. I got partway home and it did the same thing. The other problem. I have a wining noise between 37 & 43 mph. It sounded to me like tire noise. The dealer said the bearing in the torque tube was bad and it had to be replaced along with both rear wheel bearings. On the way home the car stopped again and the wining noise was exactly the same as before. As of now I am out over $4,200. CAN ANYBODY GIVE ME ADVICE ON WHAT THE PROBLEM IS AND IF ALL THE WORK THE DEALER DID WAS WARANTED. Thanks
05-02-16 04:45 AM - Post#2625665
    In response to 54BelairSC
If in fact for 4200$ nothing was fixed correctly I would sit down with the service mgr and insist this gets resolved, if no satisfaction, file a charge card dispute, or small claims court. As far as the warranty, check the time/ mileage coverage for your car, gotta do your due diligence here.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-02-16 09:43 AM - Post#2625711
http://www.corvetteforum.com/forums/c6-corvette-zr ...
AS FAR AS R&R PARTS MY DEALER ALWAYS ASKS IF I WANT THE OLD 1'S.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Sting Ray
Sting Ray
Loc: Drag City, California
Reg: 02-19-05
05-02-16 12:28 PM - Post#2625744
Curious as to what year, mileage and transmission?
Bleeds Chevy Orange
1957 Chevy 150, 3-spd
1967 El Camino, 427, 4-spd
54BelairSC
Reg: 07-12-15
05-02-16 08:03 PM - Post#2625863
    In response to Sting Ray
2005 mag red coupe with auto trans.
54BelairSC
Reg: 07-12-15
05-02-16 08:04 PM - Post#2625864
2005 mag red coupe with auto trans and 20,500 miles
Execution time: 0.166 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:22 AM
