Username Post: 73 Caprice - GEN/OIL Light Stay On        (Topic#334700)
ceasealeo23
Reg: 04-11-16
04-11-16 10:16 AM - Post#2620928
I just replaced the headers on my 1973 Caprice, and I must have tripped something as my GEN and OIL lights stay on while the car is off. It is obviously draining my battery. I tried to jump it and got it to start, however the car stays stuck in park and does not let me switch gears.
On the flip side - when the car is OFF - I can put it in neutral etc.
Any ideas?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
04-11-16 03:21 PM - Post#2621001
    In response to ceasealeo23
My first thought would be check the shift linkage to see if it is hitting or binding.
ceasealeo23
Reg: 04-11-16
04-19-16 06:08 PM - Post#2623039
FIXED:
There was a tear in one of the wires coming from the starter, and as you can see it was touching a ground screw close by
Once I pulled the wire off the screw - everything was back to normal
Edited by ceasealeo23 on 04-19-16 06:09 PM. Reason for edit: No reason given.
Execution time: 0.278 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:11 PM
