Username Post: Engine rattle        (Topic#333742)
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
03-08-16 04:27 AM - Post#2613872
Unless I pull the fuel pump fuse before starting this 97 LT1 engine and spin it for 3-5 seconds, it will rattle/knock on a cold start.
Some other odd info-#2&4 cylinders have a higher (180 psi) compression while all the other cylinders are around 170.
It seems I hear a dull knock even after it's warmed up. It does Not use any oil or water.
Can I infer it may be the rods? Would a cracked piston act the same way? Thanks
It's all good. mostly
03-08-16 12:46 PM - Post#2613995
    In response to 4dr 57
Good oil pressure, using the recommended oil? Is it louder warmed up? The compression variation is not an issue.
4dr 57
Reg: 11-10-04
03-08-16 04:17 PM - Post#2614041
Yes, good oil pressure (recently added a 1/16" washer behind the spring for a tad more at idle.)
Yes, using the recommended 10w30 oil. No, it's very much quieter when running, muted even.
I've run the valves and they are set at 1 turn down.Made no difference.
I recently read about air being trapped at the front of sbc engines but that GM had started drilling a small hole in the plug at the end of the engine oil galley, but I don't know if that would even pertain to these engines.
The lifters may have a built in design to prevent it by 97. Thanks.
03-08-16 05:39 PM - Post#2614063
Based on your info, strong chance this could be "piston slap". Very tough too confirm without a tear down.
Execution time: 0.081 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:17 AM
