Username Post: 2015 Tahoe Headlights        (Topic#333557)
Sparkywax
Loc: Indiana
Reg: 10-31-10
02-29-16 06:03 PM - Post#2612321
I need to get some better low beams for the wife's 15 Tahoe. What are you guys using and or recommend?
1955 Belair 2dr
1955 Belair 4dr (parts car)
1957 Belair 2dr
1964 Impala SS
1966 Chevrolet Truck
1968 Chevrolet Truck
1968 Impala SS 396 (Survivor)
Senior Moderator
03-01-16 04:45 AM - Post#2612378
    In response to Sparkywax
Is the Tahoe equipped with halogens, or HID's? Either way the stock headlights should be brutally bright. The halogen setup uses H11's which aren't what you would call dim.
Don't fall for the gimmicky bulbs out there, generally a halogen is a halogen is a halogen. The blue tint on the gimmick bulbs helps them create a whiter-appearing light but actually reduces some of the usable light in the spectrum.
The surprising thing is Sylvania produces their "top of the line" Silverstar Ultra with that stupid blue tint on part of the capsule; I guess they're responding to market demands. I guess you could try them out as at least that's a trusted brand, and they do claim that one to be the best of their offerings.
06 Silverado ISS / 06 Silverado SS / 06 300C SRT8 / 93 C3500 dually
Sparkywax
Loc: Indiana
Reg: 10-31-10
03-01-16 06:26 AM - Post#2612399
    In response to someotherguy
Im not sure what is in it but they don't seem very bright or at least don't beam out a far distance. Brights are really good .
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
1956cpe
1956cpe
Loc: Carlsbad, CA
Reg: 07-07-04
03-02-16 09:04 PM - Post#2612765
Sparkywax,
I'm not sure what lights are in the 2015 Tahoe but I have a 2014 GMC Sierra 1500 and the headlights are the worst of any newer vehicle I've ever owned. I've complained to the dealer, who said they were aware of the dim lights and they made an adjustment which did little to help. I googled the question, 2014 GMC headlight problems, and came up with many complaints, at least 50 posts. Some were so upset they were going to get rid of their trucks.
It may be worth your while to check into it.
Pete
Senior Moderator
03-03-16 06:00 AM - Post#2612796
    In response to 1956cpe
2014 Sierra, with projector style headlights:
2015 Tahoe, also appears to have projectors:
It must be this styling change to the projector lights when the problems came in. The designs just prior to this change are pretty damn bright.
If the Tahoe is equipped with halogens, as I said those are the H11's and they're a bright bulb. However, if the projector design is poor, there's not much you can do about that other than get brighter bulbs and hope for the best.
Does it help if you run with the driving lights on?
Sparkywax
Loc: Indiana
Reg: 10-31-10
03-03-16 03:00 PM - Post#2612898
She says the driving lights must not help. But I need to make sure she does have them on, I've never checked. Do they come on automatic with the auto setting?
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
elcamino
elcamino
Reg: 03-30-00
03-04-16 04:08 AM - Post#2612967
What model Tahoe do you have"
LS, LT or LTZ
LTZ have T4F Headlamps, high intensity discharge
LS & LT have T74 Headlamps, dual halogen composite with automatic exterior lamp control and flash-to-pass feature
If you have the LTZ with HID's then there is probably nothing available. I know with my CTS that is the case. And whats more, HID's are usually sealed to prevent tampering.
The High Intensity Discharge (HID) lighting system operates at a very high voltage. If you try to service any of the system components, you could be seriously injured. Have your dealer/retailer or a qualified technician service them.
Note - GMC Projector headlights are exclusive to the GMC.
2021 GMC 4WD Sierra Denali Ultimate 6.2L/10-sp
2022 Polaris RZR XP 1000 Ride Command
2017 John Deere X738
elcamino
elcamino
Reg: 03-30-00
03-04-16 04:46 AM - Post#2612971
    In response to elcamino
The GMC projector lamps are HIR–2 (9012 LL) High/Low-Beam Headlamp
PS-No headlight problems with my 2015 Sierra Denali with projectors built May 2015. There is a service bulletin Circa Jan 2015 that address this concern on 2014/15 Sierras, a new bulb and increased voltage to lights are supposed to correct the complaint.
Sparkywax
Loc: Indiana
Reg: 10-31-10
03-04-16 03:52 PM - Post#2613075
Her Tahoe is an LT
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
elcamino
elcamino
Reg: 03-30-00
03-05-16 04:25 AM - Post#2613144
So you have Halogen bulbs.
From owners manual page 10-35
High-Beam Headlamp (Base and Uplevel)9005 LL
Low-Beam Headlamp (Base) H11 LL
Note-To gain access to the pass side bulbs you will have to remove the air cleaner assembly from the vehicle. It can be a pita. Driver side can be reached easily. BUT never touch the bulb with your fingers, oils from skin will weaken the glass and the bulb may fail. Wear surgical gloves to avoid contaminating the glass surface.
Another tip, avoid all gimmick bulbs made in China or Korea or the crap sold on Ebay, its mostly cheap junk. Buy quality and quality is never cheap.
1956cpe
1956cpe
Loc: Carlsbad, CA
Reg: 07-07-04
03-06-16 07:37 AM - Post#2613395
My truck is an SLE but has no driving lights. I have made a formal complaint to GM. Maybe they will cough up a fix? I'll post if that happens but I'm not holding my breath.
Pete
Sparkywax
Loc: Indiana
Reg: 10-31-10
03-06-16 08:38 AM - Post#2613407
I set up an appointment and ask the service department if they have had any complaints and he said No. He said they'll check it out!?!?
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
Sparkywax
Loc: Indiana
Reg: 10-31-10
03-27-16 03:02 PM - Post#2618130
Well I drop it off at the dealer and they said the lights were extremely too low and they adjusted them up.
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
Sparkywax
Loc: Indiana
Reg: 10-31-10
10-23-23 05:00 PM - Post#2863537
Well I thought I would pop this up again. So what is everyone doing to brighten these LT lights up now?
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-09-23 08:30 PM - Post#2864027
The sealed beam halogens on my 57 were brighter than either of my 2014 or 2019 Yukons.
So I replaced the halogen high beams and HID low beams of my 2019 Yukon Denali and the halogen high and low beams of my 2014 Yukon SLT all with LEDs. Lots brighter and can see further down the road. I did need to adjust the hight of the aim on the 2019 up a little but the 2014 didn't need adjusting.
Edited by YOUNG57 on 11-09-23 08:34 PM. Reason for edit: No reason given.
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-17-23 03:03 PM - Post#2864249
    In response to YOUNG57
What kit did you use?
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-18-23 08:08 PM - Post#2864265
I shopped Alla Lighting Advanced LED Lighting for Automobiles
For the 2014 Yukon SLT
Dual high & low beam conversion, Brightest H13 LED Headlights Conversion Kit Bulbs 9008, 6000K~6500K Xenon White
Fog lights conversion, 5201 DRL 5202 PS19W LED Fog Lights Bulbs Replacement PS24W FF 6000K~6500K Xenon White
For the 2019 Yukon Denali
HID low beam conversion, D3S D3R LED Forward Lightings Bulbs, CAN-BUS Plug-N-Play Change HID Lamps 6000K~6500K Xenon White
High beams conversion, Brightest 9005 LED Headlights Conversion Kit Bulbs 9011 HB3 6000K~6500K Xenon White
Fog lights conversion, 12278-PSX26W LED Fog Lights Bulbs Replacement PS24W FF Upgrade Halogen 6000K~6500K Xenon White
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-23-23 04:13 PM - Post#2864432
Thank you.
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-24-23 12:58 PM - Post#2864463
My 2015 Silverado LT Z71 had terrible headlights and fog lamps. I replaced the bulbs with LED ones from Amazon. One set was Fahren brand and the other was Alla Lighting, Both sets of bulbs were a great improvement, and not very expensive.
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-25-23 05:49 AM - Post#2864479
    In response to dgstarr
Do you have the links to those bulbs? Thanks
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-25-23 11:11 AM - Post#2864487
Fahren H11/H9/H8, 60w 10000 lumens Super Bright LED waterproof headlight conversion kit 6500k cool white IP68
Alla Lighting 8000 lumen 5201,5002 LED Switchback Fog Lights
The fog lights are especially great because they have both white and amber LEDs and you can switch colors by pushing your fog lamp switch.
I was not able to copy the links, but you should be able to find them on Amazon. These bulbs may have been updated, because I purchased them about 4 years ago.
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-26-23 02:50 PM - Post#2864511
Thank you. I’ll check those out.
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
Execution time: 0.104 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:57 AM
