Username Post: 1930 Chevy Front Brakes        (Topic#333540)
rusty62
Reg: 03-11-13
02-29-16 12:43 PM - Post#2612229
Hi
I just bought a 1930 Chevy 3 Window coupe. (all Steel exterior). Car is now in shop having the
doors mounted with steel. Most of the wood is rotten or loose.
Anyway, back to my question.
The front end is stock 1930 springs, straight axle, spindles, backing plates and mech brakes (which are to attached to any thing)
What is available to convert to juice brakes??
IE, 1949-54 chevy truck axle & brakes..
IE, just spindles, backing plates hubs etc
IE ????
Any help?
thanks
DECEASED
03-01-16 01:31 AM - Post#2612364
    In response to rusty62
Good news! Spindles are the same on 1/2 ton trucks and passenger cars with beam axles (except 1933-36 Standard) until 1940. This means there are hydraulic brake backing plates which should bolt on.
May I assume you will be doing a rear axle swap which will take care of the brakes on the rear?
rusty62
Reg: 03-11-13
03-01-16 11:44 AM - Post#2612438
thanks again
Ray P W
Reg: 09-30-15
03-07-16 08:44 AM - Post#2613671
Rusty,
Currently available brake shoes are "organic", meaning not asbestos. Asbestos has a vastly highly friction coefficient than the "organic" crap that has been mandated by law since about 1980. However asbestos friction for a huge variety of shoe and pad applications is abundant on ebay.
My '32 Ford roadster street rod is a rocket but it wouldn't stop with "organic" friction. The front brake setup is a Ford beam axle with original spindles, Aspen/Volare rotors and GM "Metric" calipers. The rear is Ford 10" drums. Pulling the "organic" friction and installing asbestos friction was like adding a power booster, no exaggeration.
Ray W
ParisTX
Reg: 08-04-16
08-04-16 09:44 PM - Post#2643833
    In response to Ray P W
On eBay I've seen woven brake lining; but nothing listed with asbestos. asbestos very difficult to find. Have you located any?
Others recommended McMasters Carr (high friction/woven-doesn't contain asbestos). My mechanic wants asbestos or NOS or NORS woven brake lining.
Edited by ParisTX on 08-04-16 10:04 PM. Reason for edit: No reason given.
mikenath
Reg: 06-16-19
06-16-19 06:19 AM - Post#2768541
Rusty62 do you still have the old brake parts?I'm looking to restore mine to original and missing parts.
rusty62
Reg: 03-11-13
07-16-19 05:59 PM - Post#2770863
    In response to mikenath
Yes, I have the old parts
call me 817 454 6632
jack
Execution time: 0.094 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:38 AM
