Username Post: Replaced Transmission        (Topic#332944)
CHolmes
Reg: 02-09-16
02-09-16 08:09 AM - Post#2607660
Just had the transmission replaced for my 1988 C1500. Now the speedometer doesn't work and my mechanic says I need an instrument cluster part. I can't see how the instrument cluster is affecting my speedometer. Also, mechanic says he replaced the speedometer sensor when he replaced the transmission. Says he can't find an instrument cluster part to repair the speedometer. Help.
CHolmes
Reg: 02-09-16
02-09-16 08:30 AM - Post#2607665
    In response to CHolmes
Clarification - Mechanic is referring to the entire instrument panel assembly as a cluster. He says replacing all gauges is cheaper than replacing part by part.
49_Purple
49_Purple
Loc: Krydor, Sask. Canada
Reg: 08-21-15
02-16-16 12:18 PM - Post#2609252
....if the speedo worked with the old tranny, then he did something wrong. why did he change the sensor ?
58 Impala Sport Coupe 348 tripower
58 Impala Convertible 348 tripower
58 Sedan Delivery
68 Impala 9 pass wagon original
49 Chev 5window ,diesel
82 Corvette
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-01-16 12:10 PM - Post#2612444
    In response to 49_Purple
Likely it is a problem with the vss wire. Green I believe. I doubt it is the cluster itself.
that was before the DRAC setup introduced in 1992.
If it worked fine before but did not after then it is usually either wrong part or wire got pinched or broken
Old School GM fan FOREVER
Execution time: 0.117 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:54 PM
