Username Post: Adding TPI system from 89 IRoc        (Topic#330586)
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
11-18-15 07:58 PM - Post#2589956
Hey guys, long time listener first time caller. Actually I do more in the truck section as I am actually working on an 87 k5 blazer. But I'm currently building a 355 TPI. The system is the MAF system. Running the 1227165 ecm. On my truck currently is set up with a mechanical speedo cable. I was told I may need to put a speed sensor between my transfer case and speedo cable. I know it's a long shot but does anyone know if I will or will not need to do this?
Thanks for any input!
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
11-19-15 05:11 PM - Post#2590129
    In response to Xray Tedd
MAF setup on those is JUNK. I would recommend a 7730 ECM swap and run MAP. You can also run the 165' ECM with a MAP if you use the Australian Holden $12P code. As for your speedometer the 87 had TBI to start with. As such it already has a 2000 PPM VSS. If you are tuning the chip, a single switch can be thrown in the calibration to enable the 2000 ppm VSS pin on the ECM and you can use the same speed signal the TBI used. No matter how you look at it you are going to tuning the ECM to run TPI on your 355 in your K5.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
11-21-15 01:54 PM - Post#2590556
My non-expert opinion...
My Camaro runs the same ECM that you're planning on using. It gets its road speed input from the speed sensor (VSS) in the back of the mechanical (cable-driven) speedometer.
If your Blazer has a mechanical speedometer it should already have a VSS. I would think you could get the VSS signal to the '165 ECM from the same place as the existing ECM does.
IIRC, the VSS is either in the transfer case or in the speedometer head.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Xray Tedd
Xray Tedd
Loc: Missouri
Reg: 12-20-14
11-25-15 11:05 AM - Post#2591451
    In response to 1983G20Van
Thanks for the reply.
Originally I was gonna go with the 7730 ecm but I haven't been able to find the harness and ecm at a fair price. A friend of mine has the 7165 setup and is willing to trade me for a nib crane cam + lifter kit. He has all the sensors as well (more than likely I will only use the MAF sensor and buy new for the rest. And yes I was already planning on having the ecm tuned for my application.
Why are the MAF systems junk? I've heard they make tuning much easier.
Edited by Xray Tedd on 11-25-15 11:05 AM. Reason for edit: No reason given.
Execution time: 0.191 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:52 PM
