Username Post: Chevy van G20 -89        (Topic#329070)
Raggarbruden
Loc: Stockholm Sweden
Reg: 10-05-12
09-30-15 11:34 PM - Post#2579378
Hi.
Does anyone know where the vehicle number is stamped on the frame on my Chevy van G20 -89?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-03-15 03:29 PM - Post#2579906
    In response to Raggarbruden
Not sure on a G but they are typically stamped with a partial VIN on the drivers side frame rail above the rear axle assy. Sand paper will probably help.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
10-08-15 08:27 PM - Post#2581186
    In response to junkman104
Since a G-van is Unibody it may not have a Vin stamp on the "frame". I have been over and around mine and don't recall ever having seen one.
Edited by 1983G20Van on 10-08-15 08:28 PM. Reason for edit: No reason given.
10-17-15 03:51 PM - Post#2583133
    In response to 1983G20Van
i had an old g30. the vin was stamped on the front frame rail somewhere. i think there is also one thats revealed when you remove the front suspension crossmember.
Execution time: 0.163 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:17 PM
