Username Post: Pinion Seal Replacement        (Topic#328783)
flynl
Reg: 08-03-07
09-21-15 05:51 AM - Post#2577031
I have a 2000 Z28. Pinion Seal leaking. Looking for tips on replacing / tooling needed, and concerns on crush sleeve if any. Thanks
77chevy
77chevy
Loc: trusting earth to a boys ...
Reg: 01-26-01
11-17-15 02:26 PM - Post#2589622
    In response to flynl
I had one done at dealer under warrenty and they just took it apart and reusd the crush sleeve.
Now a year or two ago i did the same. Reused the crush sleeve and just did the seal.
Be sure to lube it before install.
Nows the time for a gear change or new unit if you have problems. I Just aquired another Z and have a problem with the locker. Im going with a new locker and gears and a new crush sleeve now tho.
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:31 PM
