43 Years of Service
Username Post: Brake pedal rebound problem.        (Topic#327630)
ACinSD
ACinSD
Loc: San Diego, CA
Reg: 04-25-09
08-16-15 12:12 AM - Post#2569050
I installed a CPP power master cylinder with 8" booster. When the engine isn't running, pedal is nice and tight, has good rebound, zero issues. As soon as the engine is running and the brakes are applied, the pedal doesn't rebound. What would be causing this to happen? If I pop off the fitting on the booster you can hear it suck air and the pedal returns to normal. Apply pressure again while running and it's the same story, no rebound.
The engine is a 283 with original style 2 barrel intake. We used the rear port on top of the intake for our vacuum line connection.
Any ideas on what may be causing the pedal to stay to the ground and the booster not burping?
ACinSD
ACinSD
Loc: San Diego, CA
Reg: 04-25-09
08-17-15 08:39 AM - Post#2569334
    In response to ACinSD
Rod length adjustment was the solution. It's was too long and preloading the master cylinder.
Chevelle
ChevyTalk Community Manager
Chevelle
Loc: Dana Point, CA
Reg: 08-31-13
08-18-15 05:27 PM - Post#2569675
Thank you for providing the solution Ari. Hope it helps others.
Chevelle
Community Experience Manager
I'll be happy to help just ask.
Click here to become a Gold Supporting Member and we'll turn off the ads at the top!!!
double_dave
Reg: 06-07-16
05-06-18 09:58 AM - Post#2733173
Hey - I had the same issue after fitting a kit for my 54 Bel Air. I don't know what your kit consist of but I bought a CPP firewall mount peddle assembly and a disc brake kit. Had decent peddle and return with the engine not running, but with the engine running supplying vacuum it wouldn't return all the way making the brake light stay on and the brakes binding slightly until I lifted the peddle with my foot - would slightly 'clunk' when I did that.
Anyway - after swapping out the booster and scratching my head for a while the problem was actually really simple. The kit didn't come with a return spring! Most manual brake peddle assemblies have a return spring to help the boost come back properly, but this didn't. It cost me $2 at a local hardware store - threw it on and now works a charm.
Execution time: 12.706 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:00 PM
