Username Post: Camaro Rear Spoiler        (Topic#327472)
alshoesbundy
alshoesbundy
Reg: 06-01-04
08-10-15 05:16 PM - Post#2567873
Can someone tell me what year Camaro that the larger rear spoiler become available? Thinking it was in 1972 but not sure. Thanks
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
08-11-15 08:55 AM - Post#2568040
    In response to alshoesbundy
1970 SS and Z-28 I believe.
Hey T @!
Joe
Jim McCall
Deceased
Jim McCall
Loc: Billings Mt
Reg: 02-18-10
08-16-15 04:26 PM - Post#2569197
I am not certain but I think it did not come out until 71. I worked in a Chevrolet service department from 70-74 and I do not remember seeing them before 71. In 71 I ordered the 71 Z/28 below and was thrilled to get the high spoiler.
Jim McCall
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
wagonmaster
Member #241
Reg: 04-28-00
08-17-15 11:43 AM - Post#2569380
    In response to Jim McCall
My reference was to a friend's brand new 1970 Z-28 RS/SS and it had the large spoilers front and rear. This was approx June 1970, prior to 1971 introduction. I believe that to be accurate.
Hey T @!
Joe
Edited by wagonmaster on 08-17-15 11:44 AM. Reason for edit: No reason given.
Jim McCall
Deceased
Jim McCall
Loc: Billings Mt
Reg: 02-18-10
08-18-15 04:41 PM - Post#2569661
    In response to wagonmaster
You very well could be right, as I am not certain. I just did not remember them before 71.
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
models916
Loc: Addison, IL
Reg: 05-28-10
08-21-15 04:56 AM - Post#2570171
Strike at GM caused the 69 Camaro to be produced into the normal 1970 production run. 70-1/2 Camaro changed body style and originally came with low back buckets and a short rear spoiler. 71-73 got the tall rear spoiler and the tall buckets. Could have been a cut off date that saw the tall spoiler and tall seats to appear in the 70-1/2, but I've never seen a factory built one. Lots of guys added the rear spoiler after they bought the car and would get the tall rear.
knightfan2691
knightfan2691
Loc: Elgin IL
Reg: 11-18-02
08-21-15 09:51 AM - Post#2570246
That's an awesome '71, Jim!
I really like the split bumpers on this generation.
Cort www.oldcarsstronghearts.com
1979 & 1989 Caprice Classics | pigValve, paceMaker, cowValve
"I've got bruises on my memory" __ Dwight Yoakam __ 'Thousand Miles From Nowhere'
Jim McCall
Deceased
Jim McCall
Loc: Billings Mt
Reg: 02-18-10
08-29-15 12:27 PM - Post#2571879
Found this on a Camaro forum.
Jim McCall
Coupla things
first---the RPO D80 rear spoiler for 1970 Camaro is the low version-- unless you have either a COPO 9796 car or one of a very few cars built in late spring for racers
second ----COPO 9796 rear spoilers are the 3 piece high spoilers as used on 1971 cars
third ---the COPO 9796 spoiler used the inside Firebird piece with SPECIAL end pieces fabricated to fit the Camaro
fourth ---for 1971 until the supply of low spoilers was used up some 71 cars may have been equipped with 70 spoilers but most were equipped with the new high spoiler when RPO D80 was selected
fifth----using the low profile spoiler actually increases lift at the rear of the vehicle (like 120 pounds) VS. about 280 pounds of down force on the high profile spoiler
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
08-29-15 12:44 PM - Post#2571881
I wonder what speed you would have to obtain in order for these numbers to take effect. Seems to me that a strictly street driven vehicle would see no compromise to the normal, everyday, factory handling characteristics when either spoiler was attached. Am I wrong??
Chuck
Jim McCall
Deceased
Jim McCall
Loc: Billings Mt
Reg: 02-18-10
08-29-15 02:23 PM - Post#2571900
    In response to 62sedan
Have no idea as I have 410 gears in my Camaro so needless to say I have not reached any high speeds.
Jim McCall
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
62sedan
Reg: 08-12-02
08-29-15 03:02 PM - Post#2571908
Regardless, Jim..... you have a BEAUTIFUL Camaro!!
Chuck
ZZiggy
ZZiggy
Loc: Joplin,MO
Reg: 04-18-02
10-09-15 06:29 AM - Post#2581227
1970 got the short spoiler on any model if so ordered.
Late 70 the tall spoiler became a COPO order and in 71 it was the only spoiler.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028
ZZiggy
ZZiggy
Loc: Joplin,MO
Reg: 04-18-02
11-13-15 10:08 AM - Post#2588570
    In response to ZZiggy
My 71 Camaro has 4.10 gears and it sees 120 mph at the end of the 1/4, I don't know if the short spoiler I have does anything other than look awesome.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028
1963SBHD
1963SBHD
Loc: south carolina
Reg: 09-01-11
06-30-17 09:23 PM - Post#2698240
Jim Hall prepared 3 Camaros for the 70 season and did not like the short tail lip, so opted to use the Firebird's higher wing. He called Vince Pigeon and had the COPO added for the Camaro, then became standard on the 71's. Noticed the restored # 1 Camaro is for sale and the only one left. Hope this clears it up.
NYH1
Loc: Central New Yorkistan
Reg: 07-15-09
06-28-18 05:45 PM - Post#2738434
There was no such thing as a 1970 Z-28 RS/SS Camaro. The Z-28 (LT1 350) and Super Sport (L34/L78 396) Camaro's were two different models altogether. However, one could get either model with the Rally Sport package.
NYH1.
'78 Camaro, mild Vortec head 385 stroker, 9.1 comp. Lunati Voodoo 262/268 hyd. ft. cam, RPM intake, 650 AVS carb, TH350 Coan 11" 2600 stall, 8.5" 10 bolt. 3:42 posi, 1 5/8" full length headers, 2 1/2" Flowmaster exhaust system.
Edited by NYH1 on 06-28-18 05:48 PM. Reason for edit: No reason given.
wagonmaster
Member #241
Reg: 04-28-00
07-06-18 08:03 PM - Post#2739236
    In response to NYH1
"However, one could get either model with the Rally Sport package"
Isn't that the same thing??
Hey T @!
Joe
NYH1
Reg: 07-15-09
08-05-18 11:30 AM - Post#2742016
How could it be the same thing? Yes, you could get the Rally Sport package on both the Z-28 and SS '70 Camaro's. However, the Z-28 and SS were two completely different cars altogether.
NYH1.
Execution time: 0.093 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:57 AM
