Username Post: No spark and no tach signal        (Topic#326729)
World Domination
Reg: 03-01-08
07-18-15 06:05 PM - Post#2562544
i'm basically finished an engine swap and ready to start it up.
i'm getting no spark--verified thru in-line spark tester and no rpm signal on tach when cranking.
NOTES:
This HEI/ESC distributor stayed with the "new" engine. i modified it to run w/out ESC by connecting the black and green wires on the ESC pigtail.
07-18-15 08:04 PM - Post#2562556
    In response to World Domination
Sounds like it's broke. That's about as vague as your discription.
What vehicle, what was the engine out of?
Did you verify 12 volts at the "bat" connector while cranking, not just with the key on? Did you try it with the tach disconnected? A shorted tach or wire will keep it from firing.
World Domination
Reg: 03-01-08
07-23-15 05:54 AM - Post#2563465
    In response to acardon
Solved:
Either the pickup coil was not plugged in fully to the module (most likely) or the module itself was bad (though i doubt it).
i did replace the module.
Execution time: 2.471 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:32 PM
