Username Post: No starting fuel        (Topic#326559)
Philips68
Loc: Longmeadow, MA, USA
Reg: 08-06-01
07-13-15 06:30 AM - Post#2561353
1984 cross fire. Won't start without starting fluid. Once started, if restarted with 20 minutes..OK, otherwise more starting fluid. Pump, pick-up, strainer and filter have been replaced. Friends say missing "start command"??? If so is this a computer problem, wiring problem, or??
Thanx Much!
Harpkatt
Loc: Long Island NY
Reg: 01-23-15
07-14-15 10:35 AM - Post#2561679
    In response to Philips68
clue if this car has whats called a start up injector? any possibility it got an intake/vaccuum leak? How's the gas? is it old?
Philips68
Reg: 08-06-01
07-14-15 03:28 PM - Post#2561750
    In response to Harpkatt
Thanks for response. Gas is old.....don't know about "start-up" injector....any idea where to look or what to check......haven't heard of it but am not an expert....had the car for 15 years, problem started last year.
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
07-14-15 04:42 PM - Post#2561771
http://vettemod.com/forum/index.php
THAT WAS THE ORG CROSSFIRE FORUM
THEN THE CROSSFIRE VAULT ETC,ETC
CRUZE THE FAQ SECTION.OR JOIN UP ON THE FORUM.
THE FOUNDER OF THE FORUMS WAS A MEMBER HERE WAY BACK.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-15-15 12:45 PM - Post#2568955
    In response to TAT_2
Execution time: 0.126 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:21 AM
