Username Post: CPP Steering box to Hedman header interference        (Topic#326294)
PhilaGear75
PhilaGear75
Loc: Philadelphia, PA
Reg: 12-07-03
07-06-15 05:19 AM - Post#2559754
Hello Everyone:
I have noted issues like this in the past in this forum. I picked up a new CPP -500 steering box and when I tried to install it noted the direct interference with my newly ceramic coated headers. Can anyone share what they found to be the most effective solution to get around this problem? I have given some thought to denting in the header pipe in the area of the interference however, it will likely compromise the ceramic coating on that pipe and would need about 3/8 of an inch pipe compression to give enough room for clearance when the engine is running.
Any other feedback on alternatives would be greatly appreciated.
Thanks to all.
Rich
delray56
Reg: 05-27-15
07-06-15 06:25 PM - Post#2559908
    In response to PhilaGear75
When I tried to install a 605 box in my 56 delray,it interfered w/ the 57-64 stock rams horns manifolds, After some thought I removed the bolt in side mounts and added 1/2 inch to the left side and shortened the rt side the same amount. No other mods were required. I soon will be installing a 500 series box, I expect it to clear with no issues.
PhilaGear75
PhilaGear75
Reg: 12-07-03
07-10-15 01:16 PM - Post#2560847
    In response to delray56
Thanks for the feedback. Unfortunately, I have side mounts that are welded to the frame on my '57 which makes the approach that you described difficult. Still looking for anyone who may have had a similar issue.
Member #409
07-10-15 04:16 PM - Post#2560881
If you need 3/8" more clearance, you either have the wrong headers or something is wrong with your engine installation.
Putting a 3/8" dent in a primary tube will make a difference in power for sure.
Thing is, needing 3/8" more clearance means that your headers wouldn't clear a stock steering box either. Are your headers specifically for a 55-57 Chevy? Are they new? If so, send them back.
It is not that uncommon to need 1/16" or 1/8" more clearance with "good" headers and a CPP steering box. But that's it.
DECEASED
07-11-15 10:45 PM - Post#2561093
Is your engine in the stock location?
PhilaGear75
PhilaGear75
Reg: 12-07-03
07-14-15 09:54 AM - Post#2561669
    In response to Rick_L
Thanks for the feedback so far. Headers are Hedman full length type (straight back). The engine is a small block V-8 in the stock V-8 location.
427-57
Loc: Denver, Colorado
Reg: 03-08-02
07-15-15 02:22 PM - Post#2561957
I had the same issue (although I didn't need 3/8 to clear the header tube) with my Earl's headers and the CPP500 Box. I called Earl's and they emailed me a tutorial with pictures showing how much material (and where) you can remove from the CPP500 box to increase clearance. I don't know if you can get 3/8 clearance, but you can definitely get at least 1/8 clearance out of this method. Good luck!!
"Discovery consists of looking at the same thing as everyone else and thinking something different."
Kurt
57 BelAir
ZZ502
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
07-15-15 11:48 PM - Post#2562060
    In response to 427-57
Something doesn't sound right, those headers and a 500 box should work. Is your motor centered? Can you offset it slightly?
Here's a pic of a set of Hooker Super Comps & a 500 box, it's a snug fit, but they clear about 1/8" w/ motor centered. I'll grind a little more clearance on the steering box before all done.
I used Earl Williams' new style motor mounts and they dropped right into place in the rear position Earl's provides.
Willy.
alans 55
"18th Year" Gold Supporting Member
alans 55
Loc: Amarillo, Texas
Reg: 03-20-01
07-16-15 11:32 AM - Post#2562176
here's mine with patriot 8025 headers and a 605 box. side mounts and bell housing mounts removed. no clearance issues. to be honest my 605 was on the frame with homemade mounts when I got it. I do not know if it's in the same location with the mounts you can purchase from vendors.
alan
Cruzin the Texas Panhandle,1/2 way between somewhere and 1/2 way between nowhere
www.picturetrail.com/alanan55
Drivin'my 55 Chebby 210, 355ci 4sp ,9" and playing w/my
40 Ford coupe 327/4sp/9" found and brought back home after 35 years
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
07-16-15 04:55 PM - Post#2562227
    In response to alans 55
I've done several GM 605 steering box installations and have never had a header clearance issue.
Execution time: 0.199 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 AM
