Username Post: Horse power info        (Topic#325932)
Uk49
Loc: East UK
Reg: 06-18-15
06-24-15 01:28 PM - Post#2557251
I believe my sbc350 engine was built in 77 & fitted into an Impala that was registered in 78, is there any way to find out what HP it had from factory? Thanks
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
06-27-15 07:34 AM - Post#2557820
    In response to Uk49
It's 170hp.
https://www.gmheritagecenter.com/docs/gm-heritage-...
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
Uk49
Loc: East UK
Reg: 06-18-15
06-27-15 12:44 PM - Post#2557871
    In response to Impala65SS
That's great, many thanks
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
06-27-15 01:21 PM - Post#2557879
    In response to Uk49
Stupid me, I figured the link would go to the page in question. It's page 47 of 63, if you haven't already found it...
Uk49
Loc: East UK
Reg: 06-18-15
06-28-15 10:31 AM - Post#2558009
Yes I did find it cheers, how much roughly do you reckon a wilder cam, a rebore & a new Holley 4 barrel would add to the 170? Thanks
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
06-28-15 11:42 AM - Post#2558027
    In response to Uk49
Well I'm no expert, but you can get a good clue yourself by down loading the free "CamQuest" from Comp Cams website. It's a virtual dyno where you can get good suggestions to your weight of car, the purpose you want the cam to fill etc.
It's quite fun benchracing
I'd say closer to 250hp is easy. Closer to 300hp you'll need headers and a larger exhaust.
You can change gearing to make it more "peppy". The easiest way to "torque multiply", is to just change to a higher stalling torque converter.
You can install a th700 or th200 to get a lower 1st gear (and an overdrive)
You can swap the rear axle to another with lower gears. But it's propably faster to get a new rear gear for the one you have. It's not an easy job if you never did anything like it before.
Apparently you can use it online to now:
http://competitionplus.com/drag-racing/new-produ ct...
Uk49
Loc: East UK
Reg: 06-18-15
06-28-15 02:26 PM - Post#2558058
These things have already been done to the engine
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
06-29-15 04:05 AM - Post#2558158
    In response to Uk49
You really need to pick a cam for your application to get what you want. When doing the Camquest comparison, you will see how very different results you are getting with two similar cams.
And that is only a program. In real life the variations are greater. It easy to mismatch so some "improvements" actually cancel eachother.
Uk49
Loc: East UK
Reg: 06-18-15
06-29-15 10:36 AM - Post#2558238
I can't trace the person who built the engine & I keep getting asked what the BHP is so if I had a rough idea that'd do for now
Edited by Uk49 on 06-29-15 10:37 AM. Reason for edit: No reason given.
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
06-29-15 12:21 PM - Post#2558265
    In response to Uk49
So you need to go to a 1/4mile and get a bunch of time slips then Anywhere close to Santa Pod?
There are rules of thumb for hp for a certain weight of car doing the 1/4 mile in so and so many seconds. Pretty sure there are plenty of road dynos around too.
It's impossible to say even close how many hp you have now without the actual number on cam, heads, compression.
Then we have the G-Tech pro gadget for probably less than two hundred Pounds, that gives a pretty good idea. I would get one of those. Serious streetrace drag racers used those to tune their cars, so they have got to be better than "seat of the pants feeling"-guage...
chevyman57B.C.
Reg: 08-29-12
07-14-15 12:39 PM - Post#2561718
Sounds like you want to go fast and everyone is telling you to do this and do that,
any thought of getting a lighter car nova,70 71 camero 67 68 69
VEGA 71 72 73 74 75
JUST MY THOUGHTS
Larry
Edited by chevyman57B.C. on 07-14-15 12:41 PM. Reason for edit: No reason given.
Execution time: 0.225 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 PM
