Username Post: starting problem        (Topic#325465)
gunter11
Reg: 06-10-15
06-10-15 06:51 PM - Post#2553665
New to the page need some help. I have a 98 corvette I have never had any problems then come out one day and it will not start. No lights come on when you open the door and the door ding doesn't work. I took the battery off to check for leaking on the computer and nothing. I checked to bcm for moisture and nothing. I can remover the negative cable and it will start right up but I have to do That everytime to start it. It will not even turn over without doing so. The gauges Come on with tire monitor sys service engine and low fuel until the cable is removed. I'm lost. All grounds are good on the car and can't get a scanner to read anything. Any help would be greatly appreciated!!
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
06-12-15 03:42 AM - Post#2553995
    In response to gunter11
Sounds like it may be a bad battery, Take it to a battery place like Batteries Plus, or similar. They can tell you and will do the work for free!
Hey T @!
Joe
Sting Ray
Sting Ray
Loc: Drag City, California
Reg: 02-19-05
08-14-15 08:13 AM - Post#2568758
If you can get power, see what codes are there.
Bleeds Chevy Orange
1957 Chevy 150, 3-spd
1967 El Camino, 427, 4-spd
Execution time: 0.214 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 PM
