Username Post: Cowl Induction Help        (Topic#324668)
54Cheby
54Cheby
Loc: Colorado Springs
Reg: 09-26-13
05-18-15 03:13 PM - Post#2548126
Some one very knowledgeable about cowl induction call me. I need some help with it.
72 SS 4 Speed. 402 stock.
1. Flapper closes when engine turned on, 2. Flapper opens when turned off. 3. Step on gas hard and Flapper does NOT open. I put Flow control check valve in today, it did not have one before, but operated the same. The vacuum port I'm using is rear (Pass side) of intake manifold, nothing else is teed off it. I don't know what the vacuum is. (Example 0-25) Call me 719-360-9122
54 Bel Air Power Glide
72 Chevelle SS 4 Speed, 402
34 Years of Army Service, and still going.
johnhem
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
05-18-15 05:46 PM - Post#2548160
    In response to 54Cheby
Here's a link to all kinds of wiring diagrams for 72 SS and vacumn diagrams too.
http://russ.green.home.comcast.net/~russ.green/197...
John H
72 Chevelle-454-4speed
Soon to be 502-5speed
http://www.502malibu.com
2014 GMC Sierra SLT Double Cab
Give Free Food To Rescued Animals Daily
HERE
54Cheby
54Cheby
Reg: 09-26-13
05-18-15 07:09 PM - Post#2548179
    In response to johnhem
Johnhem, thanks for the link.
I have the vacuum set up the way it is in the diagram. I just purchased a vacuum gauge and I have 10-13 in of vac at idle. When I step on it it goes off to 40 then zero, which should be when the flapper opens. Arrrrgg not working.
Edited by 54Cheby on 05-18-15 07:10 PM. Reason for edit: No reason given.
nstlga
nstlga
Loc: Colorado
Reg: 12-01-05
05-20-15 07:35 AM - Post#2548490
There has been previous discussion on this subject on this forum. Don't know if there's any help here or not but you can check.
He who dies with the most toys doesn't necessarily win, but had more fun getting to the finish line.
03-21-16 11:18 AM - Post#2616771
Ray,
Did you ever get the CI hood operating as it should? I am extremely familiar with the 70-72 CI hoods and would be very happy to help if I can.
Also, I almost never look at the Chevelle section here on Chevytalk because I participate on the Team Chevelle forums MOST of the time. If I can help, PM me or call me, 405-745-8383.
The below links are my 70 Chevelle and shows how the CI hood SHOULD work.
https://www.youtube.com/watch?v=C4XnsPAdscU
https://www.youtube.com/watch?v=Xra1mG1yE8Y
Execution time: 0.093 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 PM
