 Page 2 of 2 <12
Username Post: 29 years later .... 1960 Impala build progress        (Topic#324393)
60Impala1837
60Impala1837
Loc: Phoenix
Reg: 07-06-13
02-04-19 07:13 AM - Post#2758957
    In response to TYTILIDIE
Thanks for the encouragement. I can't wait til the trunk is done either !! It's slow going but its nice to see the panels going in.
'60 Impala Sport Coupe, 283/pg
Former:
'65 BelAir (355 / 350 hp)
'68 Caprice (donor)
My Pictures
60Impala1837
60Impala1837
Loc: Phoenix
Reg: 07-06-13
02-10-19 06:52 PM - Post#2759590
    In response to 60Impala1837
More progress on center trunk panel ..... had to add a 1/8" repair strip and weld across some big gaps because I butchered the cut on this area of the new panel. Lesson Learned - don't make final cuts until you are sure the panel test fit is fully seated on the braces.
Attachment: 01.jpg (496.5 KB) 0 View(s)
Attachment: 02.jpg (575.93 KB) 2 View(s)
Former:
'68 Caprice (donor)
My Pictures
TYTILIDIE
Gold Supporting Member
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
02-10-19 06:54 PM - Post#2759591
Looks like you're welding kind of cold. I'd crank it up some. I actually turn mine up to 5 (out of 7) when doing sheet. Makes for a lot less grinding later. Looks like it's coming together.
Me
60Impala1837
60Impala1837
Loc: Phoenix
Reg: 07-06-13
02-10-19 07:06 PM - Post#2759593
Thanks for the advice. I'm still learning and appreciate the help. I had it cranked up when I was hitting those plug welds into the 16g braces but turned it down when i went back to butt welds with bigger gaps. I'll bump it up on the next round.
Former:
'68 Caprice (donor)
My Pictures
 Page 2 of 2 <12
Execution time: 0.096 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:09 PM
