 Page 2 of 2 <12
Username Post: Biggest drawback to daily driving?        (Topic#321410)
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
02-26-15 08:21 AM - Post#2526334
    In response to 55boti
I will mention it next time he call me (hopefully with a Powerglide rear end). I just talked to one of my bosses about signing up he has a monte with some questions. This is a great community
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
duner6263
duner6263
Loc: Wilkes Barre, PA
Reg: 12-09-11
02-26-15 08:02 PM - Post#2526537
    In response to drew1987
Here is a link to a place that makes convertibles 2dr hard tops and sedans. check it out. Its amazing what they make. I would rather a original body unless I was going to make a high end restomod where a lot of custom parts would be used and fitment of all parts would not be an issue. Glad to hear he was a cool guy. How could he not be cool hes a chevy guy.
http://www.realdealsteel.com/products-page-2/1955- ...
Build it how you want not how others say it should or shouldn't be.
1955 Bel Air convertible. 283 with a muncie 4 speed.
drew1987
drew1987
Reg: 02-23-14
02-26-15 09:22 PM - Post#2526549
    In response to duner6263
Duner that is insanely awesome. What a cool thought. Build one from new!
Now if anyone knows where to get 4 door door bottoms let me know
Member:
mark68
Loc: Southern Ontario
Reg: 01-19-15
02-26-15 09:45 PM - Post#2526557
It certainly makes for some common ground
1968 Bel-Air 2dr daily driver
1962 Corvair 4dr project
I'll row my own, thanks!
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
02-27-15 08:24 AM - Post#2526635
    In response to Bob491
  • Bob491 Said:
Great answer but did you read the post he said 3 seasons and a 235, thats an inline 6.
I might shorten the the 3 seasons a bit but every thing else works fine
Oops. My bad - I saw 235 and read it as 283.
Mines the 4.3L V6, (first year for fuel injection) with the factory Hurst shifted A833 overdrive manual trans so I pull down 20-22 mpg regularly.
New technology (FI, disc brakes) in an old truck vibe. Can't beat it.
K
Chevelle Intro: http://www.popularhotrodding.com/features/1005phr_...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
Edited by Keith Seymore on 02-27-15 08:27 AM. Reason for edit: No reason given.
drew1987
drew1987
Reg: 02-23-14
02-27-15 08:52 AM - Post#2526645
    In response to Keith Seymore
That's the v6 that's literally a smallblock with two cylinderw choped off right?
I guess I am not too terribly concerned with fuel mileage. id like around 20 though. Nice 2.74:1 rear gears for a gentle cruise.
Or I can dismantle a Hybrid Camry and have 200 horsepower and 40 miles to the gallon. I am kidding. But now my mind is stuck on it
Member:
drew1987
drew1987
Reg: 02-23-14
02-27-15 08:57 AM - Post#2526647
Or, less silly, I'm sure comaro will be coming out with a new 2.0-2.5liter turbo 4cyl with 320ish horse power to compete with mustang's 2.3 320hp turbo 4. And at the same weight with shorter tired that gets 33mpg.
I wouldn't do this / couldn't afford to do this (id rather put a small in a new body than a new engine in an old body) but it's a neat thought.
Member:
Sting Ray
Sting Ray
Loc: Drag City, California
Reg: 02-19-05
02-27-15 09:28 AM - Post#2526658
I cringe every time I have to drive on the freeway with my 235, I can't imagine commuting daily in the thing. Perhaps that '56 with an sbc, even a 265, might be another story.
Besides hardly keeping up with traffic with the six, it's just so uncomfortable with that stovebolt screaming away at 55.
Bleeds Chevy Orange
1957 Chevy 150, 3-spd
1967 El Camino, 427, 4-spd
drew1987
drew1987
Reg: 02-23-14
02-27-15 12:20 PM - Post#2526703
    In response to Sting Ray
If you mean in your 57, you have the advantage of an open drive. You can throw in a 2.54:1 nova rear end like the one I just found on Craigslist for $100. That's my plan. That and probly 225/75/15 or something similar in 14. You whould be under 2000 rpms. My '50 has 4.11:1 and its a bit much at 60 2.54 years would be a dream
Member:
omarine
Loc: San Diego
Reg: 06-29-15
09-07-15 03:59 PM - Post#2574074
Drew, about the whitewalls, you can also get tires and buy white wall inserts for pretty cheap compared to the $300 coker. Atlas makes them and you can go back and forth from black to white wall as needed. You can also get white wall paint...
The inserts are on ebay...
All the best daily driving! Im all for it!
Cheers
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
drew1987
drew1987
Reg: 02-23-14
09-07-15 06:01 PM - Post#2574106
    In response to omarine
Hey welcome! What are you driving?
The day my first child was born, I Installed $280 (for all 4) radial skinny whites. Knowing I was expecting ,
The man who balanced them said that soon I wouldn't care about the wide white, I'd just consider my self blessed to be able to have a classic at (then) 27 (now 28) and wouldn't care about the skinny whites when I got a chance to drive it. He was right. Now, I actually think sometimes of throwing the white to the inside so I don't have to clean it.
Wife's water broke as she got up from the sofa to come get in the car and see the improvements radial tires made. Many of my thoughts and priorities changed that day.
Member:
DECEASED
09-07-15 07:24 PM - Post#2574130
Sorry for coming so late to the party. If you still have this problem, your easiest fix would be a 3 speed + OD trans. It was a factory option and is basically a bolt-in. The OD will reduce your engine speed 30% for the same road speed. IMO, this is a better solution than the tall Nova (or other) rear, because you don't lose any pulling power when you are going through the gears.
63Beater
Loc: Illinois
Reg: 01-17-15
09-07-15 09:15 PM - Post#2574162
I'd say it is a great idea. I've owned and driven a mostly unrestored 4 door '63 Impala as an on and off daily driver for many years, usually from April through November. It would be laughed out of any car show, but the average guy on the street I encounter thinks it's just great. I would suggest you get something with a recent engine/trans rebuild, and if you drive in traffic a lot you might wish to upgrade your brake's master cylinder. Cars are meant to be driven! As far as that '57 wagon goes..maybe his other car broke down. I had that happen once or twice.
Nomad02
Loc: Virginia Beach
Reg: 10-29-12
09-09-15 02:25 PM - Post#2574541
This topic was highlighted by the websites email tips; even so I'm a little late offering an opinion from Va Beach. We don't even have snow removal stuff here--to our detriment in recent winters. I have a '61 C20 Fleetside and have driven it daily just like the PO, a sailor who was stationed here. My attitude is the opposite of the trailer haul show people: "every day's a car show..." Yes I had to pay the piper (or an expensive but good welder) with a new floor this winter but the satisfaction of talking vintage trucks every time I stop for gas is great. Worth every penny. I pull in to work among about a dozen camry-like generic sedans every day. All I can think is "neener neener neener!!!"
'61 C20 235
CJS57
CJS57
Loc: New Milford , Connecticut
Reg: 01-18-05
09-18-15 01:43 AM - Post#2576353
Biggest problem I have in limited daily driving is the aggressive drivers during morning and evening rush hour. I just don't like to have to drive like that bumper to bumper and weaving in and out and jockeying for position. My car will do it, but it is work and stress. Next comes parking. A young 20 something mom with hungry crying children may not be as careful with her cart next to your car. After that is just the constant conversation you will be in if you stop anywhere. I happen to like it, takes time though. But driving our cars is the most fun!
1957 Belair 2Dr Hdtp, 58,000 original miles, original never rebuilt 283 engine, 245hp, Dual Fours, Tremec TKO 600 5-speed, 3.70 gears, AACA Senior in 1985
previous trifives:
1955 Belair Convt
1956 210 2dr Sdn
Edited by CJS57 on 09-18-15 01:44 AM. Reason for edit: No reason given.
omarine
Loc: San Diego
Reg: 06-29-15
10-07-15 10:04 AM - Post#2580832
Drew! sorry for the delay,i didn't realize I had a reply - still learning this site... I drive a 63 Implala two door HT, w 327, I drive it to work daily 22 mi each way and its running great right now!
Funny you mention your child, my ol lady will be induced this SAT, so I guess that will mean even less time to mess with the toys in the garage!
cheers!
oscar
DECEASED
10-07-15 12:15 PM - Post#2580851
  • omarine Said:
Funny you mention your child, my ol lady will be induced this SAT,.....
Induced to do what?
omarine
Loc: San Diego
Reg: 06-29-15
10-07-15 03:36 PM - Post#2580889
The baby was due FRI, and when women pass their due date, they induce labor.
Kind of off topic, but all that means is time to mess with my 63 (which is a daily driver) will decrease big time, hahaa!
DECEASED
10-07-15 04:41 PM - Post#2580900
Ahhh - got it now. I just wasn't familiar with the term. Thanks for explaining, and congrats on the new addition to your family.
omarine
Loc: San Diego
Reg: 06-29-15
10-08-15 07:46 AM - Post#2580999
Thanks Ray!
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
10-08-15 07:54 AM - Post#2581000
Omarine, CONGRATULATIONS AND THE BEST OF
EVERYTHING !
57belairman
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
10-10-15 11:52 AM - Post#2581490
just you wait till she finds out you called her an Old Lady.
Congrats. Hope everything goes well!!!!!!!!!!!
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible black
57 Nomad larkspur blue
57 3100 Pickup
55 2dr Sedan
56 Suburban
57210sportsedan
Loc: Germany / Georgia (US)
Reg: 02-06-03
02-12-19 12:06 PM - Post#2759748
An ancient chat, sorry to come so late ... in the 90's I drove my 235-PG 57 4 door hardtop car over 250k miles. I loved it! Only exception was running out of road before the brakes did their thing a couple of times. Every other car out there now has ABS and 4-wheel discs so as I restore my since retired baby, disc brakes are going on the front at the very least.
As far as winter driving, I tried to avoid it as much as possible because of the salt, but to be honest, parking the car on a driveway (under a tarp) for a decade took a larger toll than driving it in salt, hands down!
If you really want to drive it in winter though I would say wash it thoroughly underneath and definitely, definitely put a posi in that rear end!
Markus
57 Chevy 210 Sport Sedan
70 Triumph Spitfire
bought and sold a few more ...
TR56210
Reg: 10-28-18
02-19-19 07:27 PM - Post#2760331
Following the post, first add when you do pull the trigger, install at least front disk brakes and better 4 wheel disks. If your planning to stay with stock Coker’s, this big old car needs all the brakes you can get. Not that you will be speeding, but a panic stop in front of you might justify the cost.
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
03-02-19 01:43 PM - Post#2761129
I have a 57 2 door wagon that was my daily driver from September 1972 to January 2000. It now has 550,000 miles on it. I haven't driven it much since 2000 because I got another 57 150 2 door wagon that became my daily driver. The engine went sour when #5 exhaust lobe on the cam went flat. I had to pull the plug wire off it because it was popping back into the intake. Now has a new 283 and disc brakes. Just need to do the master cylinder and I'm back to driving it. Here in SoCal it's possible to drive these all year. I'm driving my 57 Bel Air 4 door sedan right now, until I finish the brakes on the 150. I can dig anyone wanting to drive their classics. Too many get over restored and end up being a shrine and the boss rather than the employee.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
 Page 2 of 2 <12
Execution time: 0.126 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:30 PM
