Username Post: soft brakes        (Topic#314828)
cyclops
cyclops
Loc: british columbia
Reg: 11-03-08
08-16-14 12:16 PM - Post#2477262
my stepson gave his mother a 78 L82 the brakes are very soft. removed rear wheels to bleed brakes, and found that at some point in time someone must have busted off the bleed and drilled and bushed it. not sure if this is acceptable or not.
I am just going to replace both calipers due to the corrosion.
rotors are 1.275 thick, 1.215 is minimum. is it worthwhile to have these ground?
also passenger side rear has 3 bleed screws driver rear has 2 and one plug. what are the correct number of bleeds per caliper?
any info would be appreciated,
Thanks George
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
08-18-14 09:04 PM - Post#2477885
    In response to cyclops
There are 2 bleed screws on each rear and one on each front. Check out Vette Brakes in FL. They will sell you the right parts.
Ken
36, 38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
cyclops
cyclops
Reg: 11-03-08
09-07-14 08:20 AM - Post#2482323
thanks for the help, kind of worried as to what else I am going to find.
Execution time: 0.086 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:43 AM
