Username Post: hhr relay modular        (Topic#313617)
SherryBliss
Reg: 07-13-14
07-13-14 12:37 PM - Post#2468769
can anyone tell me where the relay modular for my lights are located they will not shut off
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
07-13-14 01:25 PM - Post#2468779
    In response to SherryBliss
Which lights? There are interior lights, park lights, head lights.
Relays are contained in a fuse box underneath the hood. Almost all relays are there. They are square little boxes about 3/4 to 1 inch on a side.
The cover should have a description of where each relay is.
You can tap on top of the relay, this will often cause a relay that is stuck to shut off.
You can also pull each relay and replace it, if you can't find where it is located.
Execution time: 0.054 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:20 AM
