Username Post: No power on injectors Help..        (Topic#313603)
LYNKS
Loc: GUAM
Reg: 07-13-14
07-13-14 03:17 AM - Post#2468664
Hey everyone, I am new to this site. Okay, my problem is I don't get any voltage on both injectors when key is on and no ground on ecm as well.
Here's my story, the passenger side injector used to be working fine which I get voltage and ground. Not until when i decided to swap the good connector to the bad connector and plugged to the injector which is on the driver side.
I unplugged the four wires that goes to dist. (ICM) purple/white terminal and used a test light to make it touch and untouch the purple/white terminal the driver side injector sprayed out gas.
Now when I plugged the working connector back to the passenger side injector and tested for voltage and ground it's no longer getting any power? I don't know what went wrong.. I really hope you guys can help me out
91 CAMARO RS TBI
Edited by LYNKS on 07-13-14 03:19 AM. Reason for edit: No reason given.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
07-15-14 05:04 PM - Post#2469372
    In response to LYNKS
If you don't get an answer on this forum, visit the link below and do a search for your particular issue:
http://www.thirdgen.org/techboard/
There's a TBI specific board that should be of some help. There's a lot of 3rd Gen Camaro traffic there as well.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Chevytech
Chevytech
Reg: 04-25-04
07-15-14 06:18 PM - Post#2469394
Check the fuses in the fuse box. There should be a fuse for the injectors.
A common problem is wire damage where the injectors wires are right at the bottom of the collar that sets on top of the TBI unit. Right at, or outside, the grommet for the TBI, the wires can break or crack and short to each other, blowing the fuse.
You could also test the resistance of the injectors with an ohm meter.
At an ambient temperature of 20c the resistance of a TBI injector should be 1-2ohms.
A typically reading would be 1.2 to 1.3 Ohms
Injector resistance specs are published at room temperature or 68 degrees Fahrenheit unless otherwise noted.
Welcome to the board!
Execution time: 0.19 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:17 AM
