Rotobo
Reg: 01-03-03
04-06-03 01:15 PM - Post#207845
Whats the difference of a 1931 Chevy two door sedan and a 1931 Chevy two door Coach? I understand there is a difference, anyone know what the different is and does it affect the frame? Also where could I find a frame for a 1931 Chevy Coach? The old frame is gone around the battery box area. I was told that only a 31 frame would fit a 31, is this true? Thank you Rotobo
old_gto
Needs to Get Out More Member
Loc: Orlando, FLA
Reg: 07-13-00
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-06-03 03:09 PM - Post#207846
In response to Rotobo
As far as I know, on a 2-door coach, the rear wall goes straight down in back, to the apron that covers the gas tank. There was also a style called the 5 passenger sedan. On that one, the rear wall went down to just below the window, then there was a small hump (that bumped out to the rear), then down. I`m not sure about the similarities of the frames between the 2, but I understand that 1931 WAS a one-off type of year in many respects, and 30 or 32 parts won`t fit. I`m sure Royer, or Gene may be able to expand on this some more.
The only thing I`m sure of, is that I`m not sure of anything.
71 Corvette, 97 burb, 66 GTO, 69 Grand Prix, 65 Mustang, 65 C-10 Fleetside, 74 Camaro
Too many toys, not enough play time! |
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-06-03 03:26 PM - Post#207847
First off, Chevrolet had only one frame in 1931.Chevrolet refered to their 2 door cars as a coach.Most makers called them 2 door sedans.Chev. had just one 2 door but it came in a DeLuxe and Standard (plain) model.There was kind of a cross between a coupe and a 2 door called a 5 passenger coupe.These were rare.It had a small built in trunk on the rear.....Yes, the '31 frame is all by itself.
ChevGene
1934 Master sedan
1939 Master DeLuxe Town Sedan
1950 Styline DeLuxe Power Glide
1957 Nomad 283 PG
1963 Corvair Convertible |
Rotobo
Reg: 01-03-03
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-06-03 04:00 PM - Post#207848
In response to Gene_Schneider
Old_gto and Gene Schneider: It's going to be hard to find a replacement frame with only one year production, that I know for sure. Thanks for the help. This forum is great. Thanks again Rodney Rotobo
GMBOB
Loc: WARREN,MI,USA
Reg: 01-31-01
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-07-03 12:26 PM - Post#207849
Where are you located? I bought a used frame for my 31. The original frame is a completely rolling restored chassis. If your going original give me a call. I also might know of a stripped frame in Kansas. Thats where I bought mine. Brought it back to Michigan in a shortbed s-10, hanging out the back.
31 Chevy 5-Wdo Coupe
55 Chevy
55 Chevy 3200 V8 Hydramatic
56 Corvette
29 Chevy 2-DR Sedan
86 GMC Crew Cab (500,000+ miles)
90 GMC Suburban |
Rotobo
Reg: 01-03-03
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-07-03 04:18 PM - Post#207850
In response to GMBOB
GMBOB: This info is for a friend and she's going to rod the 31, About finished doing a completely stock 29 and she has a 31 Coach in very rough shape so she's going to rod it. A frame is about all she needs other than some sheetmetal parts. She's not using any of the old running gear. We live in Northern Ky just north of Louisville on the Indiana border. She might be interested in your frame if the price is right. My email is Boothr@iglou.com if you want to contact me. Thanks for replying Rodney
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-08-03 02:38 PM - Post#207851
You may want to try the search feature, but I thought there was some discussion a while back about using S-10 frames for early 30`s streetrods.
Rotobo
Reg: 01-03-03
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-08-03 03:56 PM - Post#207852
In response to old_gto
old_gto: Thanks for your response. I have a sore spot relating to S-10 frames. I got stuck with a S-10 frame deal with a 36 Ford PU. It was so convincing,disc brakes,Indpt Susp., PS, brake lines already in, gas tank mounted, really sounded like it was saving so much time/parts. I had the frame Professional shortened to 112 inches. BTW, the fellow who sold it to me told me the front fit okay. I believed him as you can see. I understand the S-10 frame can be used on vehicles with inside fender panels that can be altered to go around the steering unit, etc. but S-10 frames are very hard to use on "fender on frame" vehicles. Lots of junk out front that are in the way. The cab is narrower on the older vehicles and without narrowing the S=10 frame you can't channel the body as it won't straddle the stock S-10 frame. I hope this makes sense. I want folks to check into non model frame switches before getting into a mess like I did. I asked on the boards and didn't get any responses on the 36 to S-10 match, that should've been a red light, didn't take, I blundered on in. . Back to the 31, We will probably use homemade horns and go from there. This way we won't be ruining a good frame by altering it. Thanks a lot. The folks on these forums are the best. Rodney
Royer
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-09-03 12:31 AM - Post#207853
If the frame is gone around the area that the battery box used to sit, I'd suggest that you consider fabricating a repair to replace thais portion only. The frame was relatively straight in this area, and appearance is not overly critical - while strength is.
If you aren't comfortable doing this type of work, you should be able to locate a competent shop without too much trouble. If you don't have any shops that normally do this work, check with firms that regularly mount truck bodies, extend frames and wheelbases on trucks, etc.
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
Re: 1931 Chevy 2 door Coach?? Sedan?? 04-09-03 01:40 PM - Post#207854
In response to Royer
Rodney...sorry to hear of the troubles with the S-10 frame! Possibly GMBob has the answer. If that one does`nt work out, you may ask on Rob Cummings site: http://communities.msn.com/the1931chevrolethotrodproject It`s dedicated to 30`s Chevy owners. There`s about 70 members, and there`s a section called "Chevy Messages" where you can post questions. As mentioned above, if the frame is only bad in spots, repair sections may be the best bet.
berkelusa
Loc: Manchester, NH USA
Reg: 09-07-03
Re: 1931 Chevy 2 door Coach?? Sedan?? 09-07-03 02:35 PM - Post#207855
Thanks for the LINK Jim, Nice to know my little 30's Chevy site gets around.., How long you been posting here??
Rob
The 1931 Chevtolet TUB Project
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
Re: 1931 Chevy 2 door Coach?? Sedan?? 09-08-03 04:08 PM - Post#207856
In response to berkelusa
Registered July 2000, 6300+ posts! Mostly frequent the 29-41, 60-72 truck, streetrod, custom, DeeDee`s, and chit-chat forums.
sidworks
Loc: Saturna Island, B.C.
Reg: 12-03-05
01-07-21 08:02 PM - Post#2811608
The word 2 door sedan never really came into being till the 50s. A 2 door 5 passenger was a coach. 4 doors was a sedan. One didn’t need anything else to identify them.
There was a 5 passenger coupe with a trunk,
Ron
Bill Masters
Loc: Simpsonville, S.C.
Reg: 12-17-06
01-09-21 09:20 AM - Post#2811714
In response to sidworks
During the 1933 model-year, the five-passenger coupe was renamed to Town Sedan. The Town Sedan was a two-door.
sidworks
Reg: 12-03-05
01-09-21 09:02 PM - Post#2811742
In response to Bill Masters
https://1931chevrolet.com/drawings.htm
defines body styles for 1931
ron
