 Page 1 of 3 123
Username Post: SHEETMETAL- EMS AUTOMOTIVE        (Topic#305596)
EMS Customer Service
Thread Sponsor
Loc: cleveland, ohio
Reg: 04-18-10
12-05-13 05:56 PM - Post#2405163
WEB SITE: www.EMSAUTOMOTIVE.COM
WHO WE ARE:
WE ARE EMS AUTOMOTIVE, THE LARGEST PRODUCER OF OLD CHEVY SHEETMETAL IN THE USA. FOR
1935 TO 1954 CARS. WE PRODUCE FLOOR PANS, ROCKERS, 1/4’S AND EMS TAILPANS AND MORE!
EMS AUTOMOTIVE IS A FULLY INTEGRATED MANUFACTURER FROM ENGINEERING , TOOLING AND PRODUCTION, ALL PRODUCTION LOCATED IN THE USA IN OUR OWN PLANTS ( NO OUTSOURCING)
ALL OF OUR PRODUCTS LEAVE THE EMS AUTOMOTIVE FACTORY WITH OUR NAME PROUDLY ON THE PART. IF IT DOES NOT HAVE A LABEL FROM EMS AUTOMOTIVE , IT IS A COUNTERFEIT PART.
FOR PERSONAL SERVICE CHEVY TALK MEMBERS CAN ORDER DIRECT FROM EMS AUTOMOTIVE BY CALLING 216-541-4585
IF YOU LIKE YOU CAN MAIL IN YOUR ORDER. WE STILL OFFER CASH C.O.D.OR MONEY ORDER C.O.D. FOR THOSE WHO LIKE THIS SERVICE ( USA ONLY & NO EXTRA CHARGES)
EMS AUTOMOTIVE WILL SHIP ANYWHERE IN THE WORLD.
PHONE CALLS RETURNED TO ANYWHERE IN THE WORLD , LEAVE A MESSAGE IF IT IS AFTER HOURS. LANG FAXING (216-541-4989) FROM OVERSEAS IS WELCOME AND ENCOURAGED FOR CONNIVENCE AND GREAT FOR TECHNICAL ISSUES
QUESTIONS ON PRICING ISSUE THIS CAN BE FOUND IN THE EMS AUTOMOTIVE CATALOG OR IN THE ONLINE.ORDERING SECTION OF OUR WEB SITE.
MOST PARTS LISTED WILL BE AVAILABLE FOR SHIPMENT IN 1-2 DAYS, WHEN THERE IS A BACKORDER DUE TO HIGH DEMAND OR A SPECIALTY ITEM YOU WILL BE NOTIFIED , CHARGE CREDIT CARDS ARE NEVER CHARGED UNTIL SHIPMENT IS READY TO GO.
CUSTOMER SERVICE DEPT. TEL: 216-541-4585 FAX: 216-541-4989
OPEN 8:30 AM TO 5 PM MONDAY TO FRIDAY EASTERN TIME (NEW YORK CITY TIME)
SOMETIMES SATURDAY MORNING , WHEN WE ARE WORKING ON OUR OWN CARS IF WE CAN GET TO THE PHONE
REMEMBER YOU CAN CALL THE EMS AUTOMOTIVE FACTORY AND SPEAK TO US DIRECTLY, CAN YOU DO THAT WITH STUFF MADE IN CHINA? ( GO AHEAD CALL CHINA AND SEE WHAT HAPPENS)
FEEL FREE TO POST PHOTOS OF YOUR PROJECT USING EMS PANEL AND FOR THE TOUGH QUESTIONS, YOU WILL BE ASKED TO CALL US DIRECT
BUICK PONTIAC AND OLDSMOBILE, CHECK OUR WEB SITE FOR MORE INFORMATION ON THIS TOPIC AND THEN CALL US WITH THIS INFO: YEAR , MAKE/MODEL AND THE BODY & STYLE NUMBERS FROM THE FIREWALL TAG
(THIS IS A MUST FOR DECODING BUICK, OLDS, PONTIAC) YOU MAY BE ASKED TO SEND US PHOTO’S IF NEEDED.
( WE DO 35-58 FORD PARTS TOO)
IN THIS THREAD WE WILL COVER APPLICATION ISSUE’S, INSTALLATION PROBLEMS AND PROCEDURES, SUGGESTIONS FOR NEW PRODUCTS.
this is a link to our "you-tube" video of our ems automotive 53/54 chevy parts more detailed info is provided here about our sheetmetal panels
we would like your comments
Thread Sponsor
Reg: 04-18-10
12-29-13 05:06 PM - Post#2411594
    In response to DEEDDUDE
this is the link for our 1949-52 chevy sheetmetal video
covers ems parts for 1949-52 chev
Thread Sponsor
Reg: 04-18-10
01-18-14 05:35 PM - Post#2417956
    In response to DK
1-18-14
HOW TO INSTALL REPAIR PANELS AND BODY ALIGNMENT BY EMS AUTOMOTIVE
With the thousands of questions fielded by EMS CUSTOMER SERVICE every year some basic thoughts rise to the surface about the most popular questions.
WHERE TO BEGIN
The main question is to which area of the car to begin, some think it depends a lot on the condition of the body. But in reality the starting point is the same the amount of work per step changes.
Many start with the frame, and getting that ego boosting motor and trans in place . Well a lot of guys remove the the body to do frame and this causes problems if the rough metal work is not done.
A rusty body is weak and will flex when removed, and even though the rust may only be the rocker panels. movement of critical body alignments points can move. So proceeding with at least the rough metal work completed is best before removing the body. The number guys who call asking about saggy doors and what to do happens often at ems automotive.
Planning is the key to a successful resto job, although i complain about guys doing the engine and trans first. I would like them to plan for the the engine and trans when starting there body work. especially when doing major engine /trans swaps!
The 2 most critical area’s of a old street body is the firewall and tailpan, why?? each of these part as often changed/damaged . The firewall on early pre 48 bodies usually is changed to handle the small block or big block motor .
The changing of the firewall and tailpan can cause a twist in the body , it is best to set the firewall in place so it fits well to the surrounding front cowl. often the lower cowl panels need repair but it is not of concern at the moment. deal wit it after getting the firewall in place
Then we need to jump to the rear tailpan under the trunk lid, the tailpan is a difficult job for a few reasons.
Tailpans have a trunk lid to content with and often with some very shapely body line and reveals. these all must line up perfectly or the repair just looks bad.
The when a tailpan is removed a number of issue’s are in play. First the rear 1/4 panels are basically flapping in the wind, cause the tailpan is removed and often the inner trunk floor extension has been removed also
The 1/4 panel which often rolls around some to meet up with the tailpan , line up the tailpan to the body lines on the 1/4 panel. Now bring down the trunk lid to meet up with the tailpan set the height of the tailpan. We like to expect a gap between the trunk lid gap to be 1/8 of inch. although it could go as low as 1/16 or as large as 3/16 and it may never be the same totally around the trunk lid, do the best you can.
If the trunk lid or body lines do match up a common issue is the height of the 1/4. the 1/4’s may need to be shimmed up or down to square the basic geometric shape of the tailpan. Now if the trunk lid still does not close or line up correctly . When can have worn trunk lid hinges allowing the trunk lid to move at every opening or closing.( more common then you think.) and now for the most unbelievable issue we have seen at ems automotive.
The trunk lid is relatively a thinly shaped panel, even a car that has had soft clean life has experienced many openings of the trunk lid the closing (slamming of the trunk lid even by the center located handle. the trunk lid can and will slowly lose the arch or side to side curve of oem production,
This means the trunk lid widens slowly as it loses its curve, even though there has not been any body damage to the trunk lid it will flatten slightly, with only a 1/8 on each side it does not take for much for the trunk lid to not fit the replacement tailpan. with all this to consider the way we look at is that to make the tailpan and both 1/4’s fit the trunk lid . The idea behind this it make the car look good at the car show.
FLOOR PANS-- TRUNK FLOOR
We have skipped the floor pans front and rear along with the trunk floor for a reason. Repairing the floors and trunk floor will lock in the body structure. Making the proper fit up of outer body difficult without having to cut the floor lose again.
After the repairing the firewall and rear tailpan we can now move to the side of the car this would mean rockers lower front 1/4 and lower front cowl. on pre-48 cars the lower front cowl is more of a problem then the post 49 cars as well on the post 49 cars we have a larger lower rear 1/4 panel panel to deal with.
The replacement of the lower front cowl on pre-48 cars is difficult cause it usually includes the lower front door post and the bolt pattern for the front fenders. 2 critical area’s to align properly, the front door would be the lead issue here as the front fenders have some flex built into them. so there is some latitude.
Then lets jump to the lower front rear 1/4 and fill in with the rocker panel, here again we want the door to fit the door opening we do this by making the opening fit the door, This is the time we can adjust the panels to achieve the desired 1/8 inch door gap. Why do we do this, well when we are at the cruise night every one will see and judge how well the doors fit and the trunk lid, nobody will be lifting up the carpeting to measure to see if you have equal distance in floor ribbing.
Now if you have a post 49 car then we add the lower rear 1/4 panels behind the wheel opening , this section is put on after the lower front 1/4 , for these years of cars the lower front 1/4 a controlling part on side repair. the rear section is just line up the wheel opening and go. if fender skirts are used then they must be check for fit before final welding.
We have talked about alot of fitting and adjusting and there have been much talk on how to do this. I like the simple and unconventional method , I use steel pop rivets, it is easier to fit the panel put a few pop rivets in and check for fit,drill out if a adjustment is needed! The problem with tack welding is it requires cutting or grinding to change and could make your weld edge a mess when final welding begins.
Why? pop rivets are cheap and if you need a 100 rivets well it only $3 bucks. The steel rivets can be welded right through if they get in the way. Rivets that are welded over can be ground down smooth . the cleco clamps can get in the way of welding.
Hammer welding was invented before gas welding and gas before electric. welding.
We recommend m.i.g welding with a covering gas like co2. avoid gasless weld wire on sheetmetal panels. any 110 volt can do the job, Just get the biggest and most name brand you can afford. the cheaper ones only take a lot longer to do the job then the bigger ones. this applies to sheet metal only frame work will take a slightly bigger welder. T.I.G.welding is ok to, if you have that type of welder.
Now that the outside sheet metal is in place it is time to finish the floor and trunk, pretty much drop it and go now if you need to fit and trim the floors to fit, so what, your car is gonna look good on the outside ‘cause that work is done!
All floor pans are held up by some type of floor brace or stiffener. many of these are available from ems automotive some are not depending on your car.
If there are none available angle iron can work but is not great looking underneath some type of square or rectangular tubing is strong and looks good, ( check www.ems automotive.com we have some universal floor braces )
On cars where there is modification/ new seat mounting , don't forget to beef up the area where your seat will bolt to the floor, we do not want the bolt to pull out. It is best to bolt the seat to the floor brace but it may not line up, some heavier steel plate 1/8 thick is good for this and make it big enough to grab your seat belt bolts too!
When setting the trunk floor make it look good , but have some planning done for the gas tank. if changeing the gas tank check with the mfg. to see if any special mounting requirements are needed it is much better to weld them on now then after.
LOWER DOOR REPAIR KITS:
If using one of the ems automotive lower door bottom kits. The heavy gage steel inner will weld like normal, But for the thinner outer skin welding with out distortion is very tricky, The newer structural adhesives are a good choice, ( available from your local body shop supply) allowing some small welds on each end and using the adhesive the balance of the seam. Check with your paint supplier about painting these seams (unique procedure).
LOWER 1/4 PANELS:
On some the 50’s cars the 1/4 panels are getting longer and warp free welding can become a chore, the structural adhesive can be a help here also.
Fender skirts, if you are planning to run fender skirts which are popular for the 50’s, then it is best to have them available when welding the 1/4 panels. Fitting the 1/4’s to the fender skirts is a very good procedure., remember fender skirts came as factory, dealer installed and aftermarket each having there own fit and finish issue’s
HOW TO ADJUST THE BODY:
Ok we talk about adjusting the body but how do we do this?
Most bodies will need to have a slight amount pressure applied to push/pull raise/lower a section to make the door or trunk lid close nicely. even very clean untouched car need this after 60 or 70 years.
The best and easiest is on the frame that your going to use. now many guys will use a older frame for construction as not to mess up there purchased aftermarket roller frame, this is ok but remember when switching from a construction frame to the final some shimming at the body bolts may need to happen
To adjust the body i would bolt it to the frame using new rubber body to frame pads. clean the threads on the e body bolts good old rust and dirt cause problems.
when a adjustment is needed i would avoid using a hydraulic floor jack they are hard to adjust apply to much force and nearly impossible to lower in very very slight amounts.
EMS AUTOMOTIVE recommends using a mechanical floor jack ( what is this??)
it can be a crank jack or the mechanical post jack found in many
pick- up trucks. They provide sufficient force and are adjustable to very small amounts and are cheap at junk yards, I recommend 8 jacks for a major body rebuild. also handy to have a few wedges to push between the body and frame. wood wedges from hard wood are great.
Now you will be able to move the panels around to get that great fit on door gap. you may have to loosen the body bolts to get the panels where you need to, this is ok and expected.
When mounting the body on the permanent frame use a torque wrench on the body bolts over tighten can twist the body. during factory assembly torque on the bolts was controlled.
I WANT TO USE MY BODY ROTATOR:
But not for major panel installation. the body is hanging from each end with the weight of the body applying force downward installing panels in this condition can induce a stress and can cause some misalignment. it is ok for a few small panels but not for major work.
After your panels are roughed in the body rotator is a great way to do all your finish work.
Check out our web site: www.emsautomotive.com
The leader in “usa made” repair panels
DK
Loc: Napa,CA
Reg: 01-06-14
01-18-14 08:59 PM - Post#2418013
    In response to EMS Customer Service
EMS you are the BEST!
This is exactly the information I have been looking for and haven't been able to get a detailed answer as to where I should begin. My car is really rusty and is going to require much more than a floorboard patch. Now, as you suggested, I think I will start with the tail pan. The trunk is entirely rusted through. Can I start with just the tail pan and rear trunk floor pan and brace? What do I attach the floor pan to if I am to install the rear lower quarters later? I need to break this down into realistic and manageable small projects. Thanks again!
Thread Sponsor
Reg: 04-18-10
01-19-14 06:12 AM - Post#2418054
    In response to DK
yes tailpan , trunk extension and brace under trunk extension
the inner rocker generally have a flange to install the floor pans to if missing or short we add to it
Thread Sponsor
Reg: 04-18-10
01-19-14 06:13 AM - Post#2418055
    In response to DK
1/4s before the floor pan
DK
Loc: Napa,CA
Reg: 01-06-14
01-20-14 05:32 AM - Post#2418439
Last question. Before beginning with the rear pan replace ment, should I tune up the rear decklid and hinges then brace the decklid opening and quarter panels from side to side so the gaps stay or should I tack in the new metal, adjust the fit and then finish weld? Thanks for the advice!
Thread Sponsor
Reg: 04-18-10
01-20-14 05:38 PM - Post#2418665
    In response to DK
forget the brace, fix deck lid if bad, but if not real bad run with until it gives a problem, sometimes there is not much we can do with a deck lid, grind rust off of side.
unless hinges real bad leave them to, not sire if youcan new hinges or not.
the brace will get in the way and i fit the 1/4 to the trunk lid
52 deluxe
52 deluxe
Loc: prairie du chien wi
Reg: 03-09-13
02-02-14 09:55 AM - Post#2422859
    In response to DK
Are you ever going to build rear inner wheel wells, or patch panels for the front inner fender area around the grill. That I see is always rusted out?
Also, why must you use 49-50 rear skirts with the quarter panel patches?
RICKYRICARDO
RICKYRICARDO
Loc: Milwaukee WI
Reg: 10-31-11
02-02-14 10:35 AM - Post#2422872
    In response to 52 deluxe
It's usually the RH inner fender that rots because of the heater core
I am still looking for a good RH inner fender.
Winter is a grand old time,
there are no ifs or buts/But remember all that salt and grime/Can rust your bolts and freeze your -...
52 deluxe
52 deluxe
Reg: 03-09-13
02-02-14 12:35 PM - Post#2422912
... on a 51-52
Thread Sponsor
Reg: 04-18-10
02-03-14 06:49 PM - Post#2423334
a real long story
Chopperdoc
Loc: Huntsville, AL
Reg: 07-31-12
02-04-14 07:46 PM - Post#2423722
I just got your front floor pans, toe boards and trans tunnel.
My question is in what order would should they be installed?
Vic
1954 Belair 2 Door
Mild 350, 700R4
Frame off in progress
2003 Suburban
“Some people wake up, stretch and enjoy Freedom.....
Some people wake up, stretch and defend it”
52 deluxe
52 deluxe
Reg: 03-09-13
02-07-14 08:09 PM - Post#2424722
Ems.. can.you answer any of my other questions.about sheet metal? Thanks
Thread Sponsor
Reg: 04-18-10
02-07-14 08:13 PM - Post#2424723
yes ask
Thread Sponsor
Reg: 04-18-10
02-07-14 08:20 PM - Post#2424724
    In response to Chopperdoc
tunnel toe boards, floors
52 deluxe
52 deluxe
Reg: 03-09-13
02-07-14 08:48 PM - Post#2424726
My questions..
53belair
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
07-28-14 07:23 AM - Post#2472440
EMS Customer Support:
I have a door on my 53 HT that is showing no evidence of rust on the outer panel, even after sanding/wire brushing. The inner panel is definitely rusting from the inside out and has several pin holes.
I've looked at the great looking lower repair panels you have. But I've got several questions and concerns and I'm not yet willing to cut the door up just to try and figure it out. Please bear with me.
1) How does the lower hinge support get handled when both sides of the door around it are cut away? Is the hinge support a self supporting piece inside the door?
2) Do you offer just the inner piece of the door since it looks like that is all I need?
3) How do we replace the flange on the lower inner side that the door panel clips to and the flange on the bottom that holds the door gasket? It looks like neither are on the new door panel.
1953 Belair Sport Coupe,350/350/Fatman/Dako ta Digital/American Shifter/Southern Air/Ciadella Interiors
1967 Chevelle 396 Muncie
2010 Camaro II-SS
2011 Camaro Pace Car
2012 Tahoe
52 deluxe
52 deluxe
Reg: 03-09-13
07-28-14 09:31 AM - Post#2472467
My questions..
53belair
53belair
Reg: 03-25-07
07-28-14 03:26 PM - Post#2472569
2010 Camaro II-SS
2012 Tahoe
53belair
53belair
Reg: 03-25-07
08-03-14 06:44 AM - Post#2473975
    In response to 53belair
crickets.............?
2010 Camaro II-SS
2012 Tahoe
Thread Sponsor
Reg: 04-18-10
08-03-14 08:32 AM - Post#2474009
no front fender patches by headlight yet
fender skirts they fit better
Thread Sponsor
Reg: 04-18-10
08-03-14 08:39 AM - Post#2474011
1 save the old hinge support reweld back into new section
2 no sold as a kit only
3. i would think the interior guys would have something
53belair
53belair
Reg: 03-25-07
08-03-14 08:50 AM - Post#2474017
Thank you.
2010 Camaro II-SS
2012 Tahoe
WGS53
WGS53
Loc: Culver, Oregon
Reg: 10-21-13
11-20-14 05:55 PM - Post#2500267
Does EMS produce a front inner fender for passenger side for a 1950 Styleline?
1950 Styleline
1953 Chevy 150 4dr
1978 Camaro
2003 Ford F350 7.3
Thread Sponsor
Reg: 04-18-10
11-20-14 09:43 PM - Post#2500314
    In response to WGS53
not yet, were is your damage?
eplantage
Loc: Southern MN
Reg: 03-15-04
11-21-14 05:40 AM - Post#2500348
Do you have any updates on reproducing the rear wheel houses for '53-'54 Chevy's? Thanks.
Age: 67 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Thread Sponsor
Reg: 04-18-10
11-21-14 11:03 AM - Post#2500406
    In response to eplantage
NO PROGRESS YET
WGS53
WGS53
Loc: Culver, Oregon
Reg: 10-21-13
11-21-14 01:11 PM - Post#2500441
Damage is at the front bottom (about a quarter of fender), under battery tray and under vent inlet tube. I'll probably try and just put some sheet metal over it.
1950 Styleline
1953 Chevy 150 4dr
1978 Camaro
2003 Ford F350 7.3
WGS53
WGS53
Loc: Culver, Oregon
Reg: 10-21-13
12-06-14 05:32 PM - Post#2504340
Here is another one needing a front inner fender panel on the passenger side. I have over 1/4 of the panel rusted away.
1950 Styleline
1953 Chevy 150 4dr
1978 Camaro
2003 Ford F350 7.3
 Page 1 of 3 123
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:57 PM
