 Page 2 of 2 <12
Username Post: Nite Dragon - 1950 Styleline Special        (Topic#305480)
10-04-15 05:30 AM - Post#2580008
    In response to Nite Dragon
Looking good!!!!
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
10-04-15 05:20 PM - Post#2580136
    In response to Bob_Hayden
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
2blu52
2blu52
Reg: 03-12-02
10-13-15 09:56 AM - Post#2582155
Now that is what I call a "Major project".
THOMAS JEFFERSON
Nite Dragon
Nite Dragon
Loc: Orange Park, FL
Reg: 09-20-13
10-14-15 04:01 PM - Post#2582487
    In response to 2blu52
Yeah it ended up being a little more work than i thought it would be. But I enjoy fabricating and modifying. Figured since I was cutting it up to remove all the rot, might as well make it the way I want it.
Bel Air kiwi
Deceased Member RIP
Bel Air kiwi
Reg: 04-24-14
10-24-15 12:22 AM - Post#2584415
Hi Nitedragon, One of the early custom tricks you could do to the rotted hood corners is to radius them so they are curved not square. Its' quite a bit of work but the original corners are gone anyway. The other thing to be aware is that the four door sedan and two door sedan aren't as close as they look and there is a lot of messing about two make a good two door conversion. Its a lot easier to find a two door shell and then swap them out. A young metal sculptor neighbor here did one and he was amazed as to how much more work it was than you would expect.
He also fitted Buick taillights and to make it tidy he made up a simple die that pressed a base for the taillight to weld into the guard. It came out really nice with well defined edges given how simple the die was. I could find out if he would do you a set if I can track him down
Nite Dragon
Nite Dragon
Reg: 09-20-13
10-25-15 08:43 AM - Post#2584666
    In response to Bel Air kiwi
thanks for the info kiwi, I know whatcha mean about the slight differences. I didnt notice them until I got into it so it made it a bit more work, but I enjoy the challenge. It probably would have been easier if I used the whole back door as filler instead of using the 2 door lower front quarters, but the rear rockers and door bottoms were too bad. The stock hinge suicide also made the conversion a bit more tricky. The pass side is mostly done as far as the conversion goes, I think it came out great.
I like the idea of the radius corners for the hood. I might try that, I already had plans to radius the doors so that might tie in well.
Id like to see some pics of your neighbors buick taillight setup. I have some ideas in mind but havent started on them yet.
Nite Dragon
Nite Dragon
Reg: 09-20-13
04-09-16 04:58 PM - Post#2620593
Got one of the buckets made and tacked in for the buick taillights. Still have some tweaking on the flo of the light to the tailpan and im also widening the rear of the quarters to flow with the lights as well, which will close in the gap between the quarters and bumper sides.
04-10-16 06:57 PM - Post#2620802
Lookin good!!!!!!!
Nite Dragon
Nite Dragon
Reg: 09-20-13
05-12-19 08:42 AM - Post#2766227
Wow, can't believe I haven't updated this in 2 years. I have got a lot accomplished on it tho. The two-door conversion is complete, the door is stretched, and B-pillar relocated. I had a lot more rot to fix on the driver's side then the other. I had to replace the front and middle floor braces. Couldn't justify the cost, so I made them. Inner/outer rockers are replaced. A couple sections of the wheelhouse were rotted. I fixed those and rebuilt the inner wheel arch below the removable panel. I made the inner rocker from the pillar back as well as rocker panel endcap. Then made the floor pan extension to the quarter skin and finally welded the remains of the rear door skin with new front lower quarter to the body. I have the outer wheel arch ready to install but got pulled away to a house project. I'll update more when I get back on it.
Thought I had more pics of the door installed but this is the only one I could find and don't feel like hanging the door for pics.
Replaced the door corner to rocker
Franks_Old_53
Franks_Old_53
Loc: Atlanta, GA, USA
Reg: 11-16-02
05-15-19 04:38 AM - Post#2766434
Wow. Awesome work! Keep the pics coming!
Accountant by profession, wanna-be car restorer by choice
Rebuilding my Granddad's 1953 Chevy 150 https://www.chevytalk.org/fusionbb/showtopic.php?t...
 Page 2 of 2 <12
Execution time: 0.059 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:37 AM
