Username Post: 454 throwing belts        (Topic#299032)
OL55
OL55
Reg: 01-01-08
06-22-13 04:32 PM - Post#2357568
When driving the car fast the power steering belt twists and the alternator belt will come off or snap. Any suggestions for solutions?
Thanks,
Larry
models916
Loc: Addison, IL
Reg: 05-28-10
06-24-13 06:36 AM - Post#2358036
    In response to OL55
Your alignment is off. Side of belt will climb the side of pulley and roll over or fly off or break if the edge is sharp. When the alignment is correct, a modern belt can't fly off. It will pull itself deeper into the groove.
ronnie496
Reg: 04-25-21
08-28-21 12:12 PM - Post#2826152
    In response to models916
COG belt
08-29-21 09:54 AM - Post#2826206
    In response to OL55
besides alignment, are the belts the correct width? if the belts are not all the way in the groove they will want to wander out at high revs. you could make belt retainers. just get a sealed bearing of the size you want and make a bracket for it. as the belt gets driven by the crank the right side will be the slack side. that slack will be the side the retainer needs to be on. the slack will jump off the first pulley it comes to so the retainer should be near that pulley. it should not touch the belt, give it about 1/8 - 3/16 clearance. long distance between pulleys will make more slack and higher chances of belt jumping off. last time around i made all new brackets so my belts would be as short as possible. no more belt issues and it looks cleaner. but it was very time consuming.....or you could get a 4500 rpm rev limiter. lol
Edited by bobb on 08-29-21 10:20 AM. Reason for edit: No reason given.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
09-11-21 06:27 PM - Post#2826913
    In response to OL55
Get the alignment of the pullies correct, and use top cog belts.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-15-21 03:06 AM - Post#2827114
    In response to 55 Shaker
Mel Foye
Mel Foye
Reg: 09-29-00
09-17-21 11:46 AM - Post#2827262
    In response to grumpyvette
I use a safety mask and a timing light to freeze motion as belts and pulleys will show their bad behaviors. I SURE WOULD NOT TAKE IT TO RED LINE. START LOW.
Execution time: 0.103 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:03 PM
