Username Post: Sun Visor        (Topic#298337)
rayb2
rayb2
Loc: Big Rapids, MI
Reg: 09-11-11
06-04-13 06:25 PM - Post#2352000
I am trying to install a sun visor on my car. I know that the side brackets mount to the drip rail. My question is how far up does the center bracket sit from the top of the chrome around the windshield. I have tried finding measurements and have not had any luck. The last thing I want to do is drill some holes and they not be right.
Also I found that some people use sheet metal screws for the center bracket. Is this correct?
Chevs of the 40s
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
06-04-13 06:41 PM - Post#2352011
    In response to rayb2
What year and style of car are you working on? I'm going to be installing a visor on our '50 tin woodie station wagon and would like to hear the answer to your question too.
Good luck with yours!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
rayb2
rayb2
Loc: Big Rapids, MI
Reg: 09-11-11
06-04-13 06:44 PM - Post#2352013
    In response to mahlmann
I have a 54 bel air 2 door sedan.
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
06-04-13 06:47 PM - Post#2352014
The bottom of my plate (not the plates gasket) is exactly 5/16 above the trim on my 53 belair.
- '53 Belair 2 door post. Ford 8.8 rear, Currently getting CE M2, 383 stroker/TH400, and any spare change I have!
rayb2
rayb2
Loc: Big Rapids, MI
Reg: 09-11-11
06-04-13 06:56 PM - Post#2352017
    In response to Sixshooter
Great thanks for the info. My bracket did not have a gasket with it. SO I just ordered it from NCA.
Sixshooter
Sixshooter
Loc: Lubbock, TX
Reg: 07-05-11
06-04-13 07:02 PM - Post#2352018
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-04-13 07:08 PM - Post#2352020
This diagram is from the Chevrolet Accessory Installation Manual for 1953. I assume '54 would be pretty darn near the same. It looks as though the bracket in this diagram is very near the draw back for the roof panel. Also "J" nuts were used in the holes as opposed to sheet metal screws directly into the roof panel.
1951 Fleetline
kimo90803
kimo90803
Loc: Long Beach, Ca
Reg: 10-24-04
06-04-13 10:41 PM - Post#2352057
    In response to RAM_51
Another diagram from the same book shows the distance UP from the bottom of the drip rail for the side mounts, Loosely attach the center mount, attach the outer mounts, this will then locate where the center mount goes, so you won't have a load on it if you're off a bit. I've done 3 54's this way, never a problem
Edited by kimo90803 on 06-04-13 10:48 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
06-05-13 04:21 AM - Post#2352072
    In response to kimo90803
Thanks for posting the remainder of the information Jim. Was possibly going to post Fig 293, page 133 [Fig 235, page 104 in my book] but you took care of it.
1951 Fleetline
rayb2
rayb2
Loc: Big Rapids, MI
Reg: 09-11-11
06-06-13 07:02 AM - Post#2352453
Thank you for the diagrams. Do you know by chance if it lists what size screws and J nuts to use with the center bracket. I would like to try and use what they recommend and not just guess.
Vonratnick
Vonratnick
Loc: Down Under
Reg: 04-27-06
06-06-13 02:15 PM - Post#2352580
Ditto. Worked for me
There's plenty of room for all God's creatures - right next to the mashed potatoes.
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
06-06-13 03:27 PM - Post#2352602
I think I have one of those brackets that came with my car, anybody need one let me know.
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
RAM_51
RAM_51
Reg: 12-28-02
06-06-13 05:36 PM - Post#2352654
Unfortunately I do not see that the installation instructions list the sizes of those two items.
Usually when you got an accessory, all of the attachement screws etc. were supplied in small plain manila envolops. I would say that it may be a matter of trial and error until you arrive at the correct size "J" nut and screws. You would have to measure from edge of 5/8" hole to center of 3/8" hole to determine the correct "J" nut to use as a starting point.
It is interesting how the instructions show a string attached to the "J" nut so it will not be "lost behind the roof panel" [good idea]. As far as screws go, I would start with those that fit the counter-sink in the bracket properly; try shorter ones first, then go to longer until things snug up properly without going so deep as to damage the headliner.
1951 Fleetline
rayb2
rayb2
Loc: Big Rapids, MI
Reg: 09-11-11
06-06-13 07:15 PM - Post#2352691
Thanks for the help.
Chevs of the 40s
Execution time: 0.077 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:39 AM
