Username Post: New to board. 68 Impala project        (Topic#296443)
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-21-13 05:34 PM - Post#2337776
Just got a project 68 Impala and looking to this site for help along the way.
[image][/image]
[image][/image]
A few spots of rust to repair.
[image][/image]
[image][/image]
Here is the good part. 454 BBC and TH400 rebuilt.
[image][/image]
VintageCarryall
Loc: Arizona
Reg: 10-08-06
04-21-13 05:46 PM - Post#2337782
    In response to cooljunk
Assuming the rest of the body is essentially rustfree and the frame is solid; you have a very nice foundation to build on.
This I'll say: please install a decent set of front disc brakes and 3 point seatbelts for safety reasons! Brakes from either a 1969-70 Chevy big car or 1969-82 Corvette will work along with a late 1960's big car master cylinder/booster/proporti oning valve setop.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-21-13 05:52 PM - Post#2337785
OK, got that first post to work with pictures. javascript:void(0)
The plan for the Impala is to patch the rust spots, lower it! The PO installed HD front springs, thus the 4X4 look, wil try cutting coils in front. Have learned from this site that S10 front springs also work.As to the rear, I jacked it up today to powerwash the underside and found some surprises!!
The rear axle not centered, panard bar bent, rear of the car held up with wood blocks, and the right upper control arm and frame bracket missing.
[image][/image]
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
04-21-13 06:45 PM - Post#2337805
I have seen 2x4's between the coils but nothing like this. What is your location?
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-21-13 06:48 PM - Post#2337806
    In response to aghaga
Michigan
59fins
Member #212 "19th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
04-22-13 06:34 AM - Post#2337905
The control arm brackets come up on eBay from time to time, someone probably switched the rear end and did not have that bar and bracket that mounts to the frame, my 67 is a 10 bolt and does not have the l bracket/ bar on the rear end at all, I purchased the bar for when I switch to 12 bolt with the second bracket/ bar, so it is not necessary to have 2 on the rear to work properly, but all you need is the bracket (bolt holes are in the frame) and the bar is a direct fit
Bill H.
67 Impala SS
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-22-13 07:03 AM - Post#2337920
    In response to 59fins
Thanks for the info. It has a 12 bolt in it so that is prolly the answer. I see the holes in the frame so I will try to come up with a bracket and control arm.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
04-22-13 07:54 AM - Post#2337928
Make sure the arm is from a 67-70 as the 65-66 are longer.
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
04-22-13 09:22 AM - Post#2337953
Cool car, remember the spring rate will essentially go up if you shorten the springs. If it's HD springs, the spring rate will definitely be higher than otherwise. Personally I think the higher look has an "old school hi-per"-feel to it but of course the handling will improve with a lower center of gravity, I'd use softer springs for it though.
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
04-23-13 12:54 PM - Post#2338339
    In response to Impala65SS
Global West sells the upper rear frame brackets for $39 each if you can't find one.
1967 Grande Parisienne 4DR HT
My Flickr page
59fins
59fins
Reg: 04-07-00
04-24-13 06:18 AM - Post#2338581
BTW- Welcome to Chevytalk, best Chevrolet Forum on line!
No question is a dumb question if you don't know the answer.
Bill H.
67 Impala SS
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-25-13 04:02 AM - Post#2338845
I have a set of old and crusty Keystone mags with the car. Since this is a low budget project any ideas for rehabbing them? Polish? paint? powder?
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-30-13 12:14 PM - Post#2340544
Got the bent panhard bar out today. what a job, had to use the gas wrench.
[image][/image]
Anyone know how long this is supposed to be? A friend makes street rod control arms, think I will have him make an adjustable one.
Edited by cooljunk on 04-30-13 12:42 PM. Reason for edit: No reason given.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
04-30-13 12:21 PM - Post#2340547
Also put the panel below the rear bumper on for fitment. The only mounting I could find was 2 small bolts at the center. I know there has to be something supporting the outer ends!
[image][/image]
wheelman
wheelman
Loc: Long Island--New York
Reg: 04-14-07
04-30-13 03:31 PM - Post#2340609
There are 2 bolts that attached to the liscence plate bracket and one bolt on each end that attach from inside the lower rear quarter panels
1968 Impala Sports Coupe
2004 Jeep Grand Cherokee
Save a Classic - Crush an Import
[url=https://www.facebook.com/greg.leonovich [/url]
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-02-13 03:41 AM - Post#2341107
    In response to wheelman
Thanks, found them. The quarters were patched and no holes drilled.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-06-13 03:44 AM - Post#2342366
Cut 2 coils off the rear.
Before and after.
The wheels and tires are too big with 3" BS rubbing on outer edge. Also with the cut coils if I drop the axle from the frame (jack it up at the frame) the springs come out of the upper spring seat and won't go back in. Will have to limit the axle drop to keep the springs in place. Shorter shocks or?
On to the front coils next.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-06-13 06:07 PM - Post#2342656
Cut 2 coils from the HD coils up front, not enough! Cut 3 coils.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-15-13 06:39 PM - Post#2345825
Help wanted with wheels. I got a set of chrome wheels.
Would like to make them look more like this.
Any ideas on paint type to get a look like that for the black areas?
Edited by cooljunk on 05-15-13 06:40 PM. Reason for edit: No reason given.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-15-13 06:50 PM - Post#2345831
Also got my panhard bar done. I started with a piece of angle iron drilled 9/16th holes 35" centers and installed it for mock up. An inch off, 36" just right.
Had my friend Fred at Vintage Rodder Burton Mi. make an adjustable bar 36" long, The bushings are a little narrower so some shimming is needed. Came out great. Forgot to take a picture before install
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-15-13 07:00 PM - Post#2345835
Got new air shocks. The old ones were allowing the axle to drop too much and the cut springs were coming out of the pocket. Shortest I could find was 20.7" extended. Worked but marginal.
Decided to move the upper mount 1" inboard to shorten the drop.
Now I can jack the car up without the springs popping out.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-19-13 06:41 PM - Post#2347136
Some progress on the wheels. Started with a wire wheel on a die grinder.
Too much work and scratching chrome. went to stripper.
That works better.
Need some work with die grinder on lug area, then will try cast blast paint.
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
05-21-13 01:32 PM - Post#2347704
Finally got around to starting the 454. A bad noise!!! Pulled it out.
Found rod bearings 1&2 in bad shape, spun.
Had a good 454 in the shop so I will install it.
The headers were hanging below the frame, would have hit with the new low stance so will go with iron manifolds. I am trying to get this car on the road for the Woodward Dream cruise in August.
VintageCarryall
Loc: Arizona
Reg: 10-08-06
05-21-13 06:03 PM - Post#2347777
That just bites. At least you caught the problem before you hit the road but still...........
Airflow
Airflow
Reg: 09-26-10
05-29-13 10:46 PM - Post#2350210
Good job! That'll be an awsome car! Love your picture of the rearend. Lovely back lights!
Good thing you got the shorten rear sjocks and don't have to worry about the rear coils anymore!
Looking forward for more updates!
What color will you be painting it?
wheelman
wheelman
Reg: 04-14-07
05-30-13 06:16 AM - Post#2350264
    In response to Airflow
I'm wondering why your rear sat so high ? Even with stock suspension and coil overs mine sits closer to your after picture ..
I still have issues with the ride feel even with S-10 springs and adjustable drag shocks the front is too rigid I just can't get it figured out
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
06-02-13 02:15 PM - Post#2351250
More progress on the 68, better 454 installed and fired up;
Got 2 of the wheels painted,used Dupli-color cast iron.
Have not decided on a color, maybe white probably satin finish as it will not be pro body work and I like satin look.
alocker
Loc: IL
Reg: 10-05-12
06-03-13 07:11 PM - Post#2351696
Keep up the good work. Interesting that the car has later style motor mounts.
wheelman
wheelman
Reg: 04-14-07
06-03-13 07:13 PM - Post#2351698
    In response to alocker
I used Dupli Color Rally Wheel paint in Ardent Silver
cooljunk
cooljunk
Loc: Michigan
Reg: 04-20-13
06-07-13 12:07 PM - Post#2352890
OK, time for some help from the board. I started to fab some shift linkage from my column to the TH 400
The shift lever was not in the column so I put it in and pined it. The lever moves ok and feels like it is working right but the lever at the bottom of the column is not moving. I can push it(the bottom lever) up and down without moving the upper shift lever. Any ideas? diagram of the workings of the column?
Execution time: 0.157 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:05 AM
