Username Post: Corsica 3.1 Misfire        (Topic#294383)
Bilster
Bilster
Loc: Albuquerque, New Mexico, ...
Reg: 12-12-02
03-05-13 05:00 PM - Post#2323376
Hello,
I have a 1993 Corsica with a 3.1. It has a misfire. It didn't pass emissions because of excessive HC. I thought I had it diagnosed as a bad coil because two plugs were fowled and they both led to the same coil. Replaced the coil with a new one and still have the miss. Wires are new. Any ideas? Fuel filter and pump are new.
Edited by Bilster on 03-05-13 05:01 PM. Reason for edit: No reason given.
Trailbum
Member #727 Longest Supporting Member "20th Year"
Trailbum
Loc: Harpers Ferry, WV
Reg: 11-06-00
03-05-13 09:07 PM - Post#2323457
    In response to Bilster
I would do a compression test first, to make sure you have adequate compression in those two cylinders. If the compression is good then try the following link to test the ignition module, coils, etc...
http://easyautodiagnostic s.com
"They say men should get in touch with their feminine side.... Well, if I HAD a feminine side.. believe me, I'd be TOUCHING IT!!!"
Bilster
Bilster
Reg: 12-12-02
03-06-13 04:28 PM - Post#2323689
    In response to Trailbum
Thank you! I'll give it a whirl.
Execution time: 0.103 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:19 AM
