Username Post: 3.1 Engine Idle Issue When Engine Warm        (Topic#293503)
Mark's '41
Reg: 09-13-04
02-14-13 07:12 PM - Post#2316911
Hi: My '92 Olds Cutlass 3.1 engine normally runs great, but after the engine is warmed up, it will die while idling in both drive and neutral. The idle is normally fine, but will then all of sudden get rough, flutter, and either recover (and return to normal) or die. When the car is idling from a cold start there is no problem - the problem appears once the engine warms up. Injectors are good, intake manifold gasket is good, it has a new fuel pump, IAC, and hoses and wires are in good shape. Any ideas?
Trailbum
Member #727 Longest Supporting Member "20th Year"
Trailbum
Loc: Harpers Ferry, WV
Reg: 11-06-00
02-28-13 08:17 PM - Post#2321606
    In response to Mark's '41
Try http://easyautodiagnostic s.com
Very straightforward and simple tests. Great explanations. Helped me out with a misfire in my '91 Cutlass Supreme 3.1
"They say men should get in touch with their feminine side.... Well, if I HAD a feminine side.. believe me, I'd be TOUCHING IT!!!"
Execution time: 0.325 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:36 PM
