 Page 9 of 11 « First<891011
Username Post: 55 Sport Coupe - 396 LT1 - T56        (Topic#292613)
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-30-18 02:38 PM - Post#2750029
    In response to 2Loose
With some shims between the steering box and the frame,
I could get better alignment with the steering column,
but I'm too close to the headers already, so the steering
box will stay where it is...
This is the misalignment I'm referring to,
but that rag joint should be able to handle it ok...
I found this original rubber sleeve from the original
steering column, just needed to put in a locator
bolt to match the slot in the bottom of the steering column...
Everything bolted up quite nicely...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-30-18 02:42 PM - Post#2750030
Dug out the shift lever and boot...
Screwed down the boot, lookin' good there...
Hung the clutch pedal, now to figure out how to hook up a juice clutch MC...
(the T56 has a hydraulic operated throw out bearing)
Pulled this new brake master cylinder off the shelf (for the brakes),
not sure how to hook up that compensating valve...
From the numbers here, it's been sitting on the shelf for about 10 years...
Got some work ahead of me....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-04-18 08:03 PM - Post#2750482
I'll let you guys figure this out...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-06-18 11:27 AM - Post#2750616
Oh, Wait, I need to pull that steering wheel hub back off so I can screw down the turn signal lever....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-12-18 11:59 AM - Post#2751164
Back on my '55 hardtop project, I'll be using this diagram for the fuel pressure regulator hookup...
Fuel pump pressure inlet to the main PR on the left, controlled pressure outlet feed to the fuel rails on the right, return secondary PR feed from the fuel rails to the return line at the bottom of the main PR....
An alternative method would be to modify the fuel rails and put the return PR and return line out at the other end of the fuel rails, but I'm going to try it this way first...
-Willy-
More photos HERE...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-12-18 07:44 PM - Post#2751214
Looking for the right size bolts for those fuel rails to the plenum
and noticed the plenum only had 4 rusty bolts, so dug out
some ss allen head bolts and washers, and installed them...
I've always had good luck with a copper anti-seize when using
ss bolts in aluminum heads...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-13-18 09:03 PM - Post#2751332
Hung the main fuel PR valve and hooked up hoses, eventually it will probably need to be modified after the front fenders are on, but for now....
And no, that return line is not as close to the headers as it looks in this pic...
More pix here, (scroll down...)
Willy
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-16-18 02:56 PM - Post#2751556
I'm going to have to dig around and find out what all these ports are for,
These four are on the left side of the plenum...
These two are on the right side...
This one is on top of the front, right corner of the plenum...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-16-18 09:14 PM - Post#2751579
Here's 8 old pix of the original motor,
freshly pulled out of the wrecked '93 Camaro Z28, LT1
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-23-18 04:47 PM - Post#2752222
Got my hands on an original '93 Camaro shop manual, these two ports on the right side of the plenum are vacuum ports, the upper one is hooked to the original fuel pressure regulator vacuum port, which I'm going to leave open to the atmosphere for now, and will just plug this port, and the lower one in the old original pic is hooked to an "Evaporative Emission Canister Purge Solenoid Valve"....
Hmmmmm....
The large port shown below is apparently a connection to the crankcase, and is setup as a "crankcase vent recirculation valve", which you can see in the second pic...
I think I might keep that also, but fitting the crankcase connection to a road vent tube like the older motors used would be ok too....
I think both the upper small ports are just vacuum ports, one is shown in the old pic as a brake booster vacuum connection....
I really have no idea what this hole in the top, front, right corner of the plenum is for, or what the device plugged into that hole in the second pic is....
(scratching the head....)
These rear ports I'd blocked off earlier, they are EGR (exhaust gas recirculation) ports, that I'm not going to use on this car...
The lower pic shows some of the hardware for that device...
More Later...
Willy
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-26-18 06:14 PM - Post#2752463
Messed around some more with how the fuel hoses were laid out at the pressure regulator...
And bolted in a new Optima red top in the trunk...
MORE pix here....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-30-18 10:21 AM - Post#2752905
I put a 90 hose end on at the inlet side of that fuel filter, looks a lot better now...
I'll mount that filter on the side of the inner fender when I put the fenders back on...
WagonCrazy
WagonCrazy
Reg: 06-07-05
12-01-18 08:44 AM - Post#2752989
You're making great progress Willy. Stay with it...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-01-18 11:13 AM - Post#2753002
    In response to WagonCrazy
Have one port on the right side open for a vent to the Optispark...
New parts are on order for the crankcase vent system, which uses
those two lower ports, plugged the upper ones for the time being...
And finally learned that this top port on the plenum is for a MAP sensor...
Pulled out all the wiring and electronic gear, and started scratching my head...
More later....
( I hope !)
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-01-18 04:01 PM - Post#2753024
My local Napa auto parts store had what is supposed to be
the correct MAP for this motor....
But it obviously needs a seal of some kind, which did not come with it...
So the search continues...
Pulled the new throttle body off the shelf to mount...
And found that there is a part missing underneath, now I need to
find out what else is needed and go find it. It did come with a
gasket for whatever is missing...
Hmmmm....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-03-18 11:27 AM - Post#2753202
Here's a pic of an original '93 LT1 MAP sensor and seal,
looks like some kind of soft sleeve...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-05-18 11:26 AM - Post#2753488
Found an old original MAP seal, but would much prefer a new one...
Will go back and hit up my local Napa store...
Found a piece of 1/8" aluminum plate in the scrap pile...
Cut out a cover plate for the throttle body hot water passages,
now I need shorter screws...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-07-18 11:42 AM - Post#2753752
Managed to find some (metric) m4 size ss allen head screws for this cover plate, still a little long, had to trim them slightly to get a good fit, but it came out pretty nice, also used flat and lock washers under each screw....
More pix here (scroll down)
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
12-07-18 04:22 PM - Post#2753777
Please keep posting! I personally would't know where to begin on a project such as this; I just can't wrap my head around "modern fuel injection". Maybe this will help me understand it better.
I am Butch/56sedandelivery.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-08-18 01:51 PM - Post#2753895
Oh, I'm learning, and it's a steep learning curve !!
Worked up a list of sensors needed for this
'93 LT1 speed-density efi system:
1. MAT
Manifold Air Temperature
This fits in the air ducting in front of the throttle body,
I need to find one.
2. ECT
Engine Coolant Temperature
Not sure what this looks like or where it goes.
3. IAC
Idle Air Control
I think this goes on the end of the throttle shaft
on the throttle body, I need to find one.
4. TPS
Throttle Position Sensor
Again, I think this goes on the throttle body someplace,
I need to learn more about this one.
5. MAP
Manifold Absolute Pressure
Bought a new one from Napa,
it needs a special seal that did not come with it,
might have to just use silicone sealer.
6. Knock Sensor
I need to find the correct one and
where to mount it.
7. O2 (Oxygen) Sensor
I have one, need to weld a bung
on one of the header collectors for it
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-19-18 02:40 PM - Post#2755039
I've been slowly finding the parts I need online, most of them from Rock Auto...
but still need a body (housing) for the IAC (Idle Air Control) on the bottom of the throttle body.
My cover plate I fabbed isn't going to do it...
Found this on the evilbay site, but they refuse to ship to Hawaii/Alaska...
They must think we're not a part of the USA yet....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-19-18 02:41 PM - Post#2755040
I contacted the seller, they agreed to mail it to me in Hawaii...
ROUTE 55
ROUTE 55
Loc: Minnesota
Reg: 05-17-07
12-20-18 06:40 PM - Post#2755155
I agree with Butch. Also, I really enjoy watching your progress. Keep it up !
Dave
55 Belair HT 396-L78 BB, 4sp Muncie, 12 bolt Posi.
rcr3
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
12-21-18 02:25 AM - Post#2755178
    In response to ROUTE 55
Dave
+1
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-24-18 08:11 PM - Post#2755524
    In response to rcr3
Finally located some O-rings for the MAP sensor probe that will fit snugly in the plenum hole,
four fit nicely on the probe, it should be ok....
Cut the water heater off of the IAC housing, and got a new probe to fit it,
and cut my cover plate to fit around the IAC housing....
And with a lot of shopping around, I think I finally have all the probes and sensors I need....
I'm learning a lot, I just hope I'm learning enough to not make any serious mistakes,
Merry Christmas everyone !!
-Willy-
More pix here (scroll down)....
rcr3
rcr3
Reg: 11-24-02
12-25-18 05:01 AM - Post#2755542
Merry Christmas Willy !
'12 Cruze RS LTZ
'74 Nova Custom cp.
'17 Chevy Trax LT
'00 S10 Ex cab
'67 Camaro survivor
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
12-30-18 07:40 PM - Post#2756055
    In response to rcr3
Living on a small island has it's disadvantages....
Searched every store that has bolts and screws, and could not
find the ss allen head metric screws I wanted, so drilled it to the next size
for the 3 screws for the IAC and tapped it for 10-32 ss allen heads
with ss lock washers....
And the same for the TPS, with ss flat and lock washers....
Both installed with anti-seize, as this is ss and aluminum, want that anti-seize in there....
ROUTE 55
ROUTE 55
Loc: Minnesota
Reg: 05-17-07
12-31-18 10:47 AM - Post#2756123
Your persistence and quality of work is a real inspiration to many of us here.
Happy New Year to you and to all of us on CT.
Dave
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
01-01-19 10:33 AM - Post#2756255
Decided to re-tap the threads in the plenum for the throttle body with 5/16"-18 NC,
and to use the ss allen head bolts I have....
All of my taps are sets of three, with different starting tapers,
the one on the right is a bottoming tap for blind holes....
I like to use a cutting fluid to prevent any galling when cutting new threads...
Taped off all holes where debris from the work could get in....
The metric threads that were in this plenum very closely matched the
new 5/16-18 threads I cut. I'm not happy about doing this, but there's
enough solid threads here that it will work out just fine....
I considered bumping it up to a 3/8" fine thread, redrilling and tapping,
but that much bolt seemed like serious over-kill, and the way I did it still
had enough solid threads in there that it will be just fine !!
All mounted up with never-seize and ready to go....
HAPPY NEW YEAR TO ALL !!
And maybe I can get this rig running this year !
WagonCrazy
WagonCrazy
Reg: 06-07-05
01-01-19 05:06 PM - Post#2756291
Fantastic hot roddin' there Willy! Glad to found a way to make that work. You're engine is lookin' gooooood. Stay with it.
Happy New Year.
Paul
Execution time: 0.086 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:48 AM
