http://www.cardomain.com/ride/222599 To be born a Redneck is by chance, to live as one is by choice!
Good eye Willie, Had you not pointed it out I wouldn't have noticed the three. Good to see some forward progress.
Had a few minutes so drilled 1/4" holes 2" apart in the floor along
the right edge of the opening, and spot welded one if the
1" strips under that side with 1/2" exposed....
Tested some bits and settled on an 11/64" for the pilot hole
for these #10 sheet metal screws. Drilled them 2" apart,
will use this as a template to drill 11/64" holes in the strips
I welded in under the edges of the hole....
Later I'll drill these holes in the cover to 13/64" to better accomodate the screws...
