 Page 11 of 11 « First<891011
Username Post: 55 Sport Coupe - 396 LT1 - T56        (Topic#292613)
HYPR
HYPR
Loc: Shaking and Burning!
Reg: 07-19-01
02-09-19 05:22 PM - Post#2759506
    In response to 2Loose
HYPR
HYPR
Reg: 07-19-01
02-09-19 05:26 PM - Post#2759507
Good eye Willie, Had you not pointed it out I wouldn't have noticed the three. Good to see some forward progress.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
02-10-19 11:17 AM - Post#2759556
    In response to HYPR
Got family visiting so work has slowed down a bit...
Dug around in my scrap pile until I found this piece of 14 ga.....
And cut 2 pcs 1" wide....
I'll fit these in under the edges of the opening
to mount the cut pieces back in...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
02-10-19 03:58 PM - Post#2759574
Had a few minutes so drilled 1/4" holes 2" apart in the floor along
the right edge of the opening, and spot welded one if the
1" strips under that side with 1/2" exposed....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
02-16-19 12:13 PM - Post#2760050
Found a couple of minutes to do a little more....
Got three sides done...
Trial fit looks good
Will add some additional welds underneath....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
02-18-19 11:16 AM - Post#2760210
Tested some bits and settled on an 11/64" for the pilot hole
for these #10 sheet metal screws. Drilled them 2" apart,
will use this as a template to drill 11/64" holes in the strips
I welded in under the edges of the hole....
Later I'll drill these holes in the cover to 13/64" to better accomodate the screws...
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:23 PM
