 Page 13 of 13 « First<10111213
Username Post: 55 Sport Coupe - 396 LT1 - T56        (Topic#292613)
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
09-21-19 06:04 PM - Post#2776089
    In response to 2Loose
One of these would be much simpler.
https://www.lowes.com/pd/Hillman-2-Count-1- 2-in-St...
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
09-21-19 06:07 PM - Post#2776091
Charles
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-26-19 09:20 PM - Post#2776549
    In response to WagonMan
Yeah, I know, but I did have fun dreaming up the disk idea and fabbing it....
Glued the disk to the back side of the dash
where the switch goes, it worked out great !!
When I tried to fit the left side wiper shaft in place
with the motor and other parts attached, the motor hits my
hydraulic clutch MC pedal offset, which is centered on the
MC, so I can't move that....
I can rotate the wiper motor 120 deg in it's chassis, as long as
I keep the critical alignment of the motor shaft relative to the
"shut down" or "off" position of the motor shaft....
But a close look here shows that I'm going to have to relocate the fuse panel,
as that wiper motor will hit it in the new 120 deg clockwise relocated position !!
Pulled the fuse panel and all that attached wiring out to make room....
Also, if you look at the top of that last pix you'll see that I
still have the stock defrost ducting in place, I found that I
need to remove that as well....
I have new Vintage Air system on order, I'm told that
it will have new defrost ducting that will clear the Rain Gear setup....
During all this, I've had several good conversations with the folks
at Rain Gear, and they have been quite helpful....
Then made sure the motor was in the "shut down" position,
carefully loosened the nut on the motor where the drive arm is mounted,
and pulled the motor off.
With the motor off, carefully fitted the rest of the assembly into
position under the dash, all looking good....
Except....
Getting some rubbing on the left side of my clutch offset
against the right side of the wiper assembly,
but I think I can deal with that once I get the wipers all in
and aligned....
I carefully remounted the motor in the new position,
and carefully reattached the drive arm in the "off"
or "shut down" position.
Now let's see how well all this is going to fit....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-26-19 09:21 PM - Post#2776550
There's an anchor bracket bolted to the firewall
in the center of this pix, I had to bend it a bit to
get the fit I wanted with clearance from the
clutch pedal bracket....
It all bolted together pretty well....
Lots of clearance with the clutch pedal bracket....
The escutcheon doesn't fit very well on the driver's side....
No problem on the passenger's side....
Think I'm going to remount the fuse panel cross wise and lower....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-28-19 05:05 PM - Post#2776644
Drilled a couple of holes, got some bolts and spacers, and it's good to go....
Needed to rework that lower mounting bracket to pull the
wiper chassis in toward the firewall, lifting the angle of
the wiper shaft up to get a better fit....
This is where it fits, that stud is where I'm trying to pull
the assembly in toward the firewall....
And it worked, I got lucky, it popped right into place
after reworking that bracket....
look at the pic above a ways to see the difference....
And I still have clearance with the clutch pedal....
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-01-19 06:49 AM - Post#2776832
Good work Willy. Keep at it. Wipers are important on Maui...
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
10-03-19 01:19 PM - Post#2777006
love the amount of work and thinking u put into making the wipers work.
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-04-19 06:34 AM - Post#2777068
    In response to 498 chevy
regarding the placement of your fuse panel- put it where you can easily get to it. it's rough having it up under the dash if your in there often to troubleshoot.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-09-19 11:39 AM - Post#2777483
    In response to WagonCrazy
The fuse panel's pretty easy to get at now, I like the new location much better than where it was originally....
Just noticed that the windshield washer nozzles on the escutcheons are missing, the holes plugged up with screws....
Have not been able to find replacement nozzles, except already mounted on new escutcheons, so I ordered a new pair....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-09-19 11:53 AM - Post#2777485
The BeCool radiator setup includes the
front end AC stuff....
And the motor has a new AC compressor....
The rest of the Vintage Air system to go under the dash just arrived from Danchuck....
Scratching my head and reading over 60 pages of instructions....
And going over the parts, I have fond hopes of making this all work....
The first thing is to fnish stripping the dash,
which was already pretty much stripped,
I pulled out the defrost vents, which will be replaced....
And attached the mounting brackets on the evaporator unit....
Hmmmm, hope I did that right....
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-09-19 03:15 PM - Post#2777492
Willy, I sent you a P.M. about parts. Been following this build since you started it; just like you did with "Patches", the 55, 4 door, Street Gasser. Keep it up, and posting as you go! You're one of my "pseudo-hero's"; but only because your builds are something I wish I could still do. And, Hawaii is the ONLY other place my wife would ever move too, and we've discussed it many times, but I have a real issue with heat. Can't wait to see the final results of this build/car. I am Butch/56sedandelivery.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-11-19 09:42 AM - Post#2777665
Although I've worked with classic cars all my life, never got involved with AC until this one, so taking my time and trying not to make too many mistakes!
I was disappointed to learn that this Vintage Air setup does not include any option for outside air, it is strictly an inside air setup, I looked at possibly modifying it to include a choice of outside or inside air, and backed away from that idea. The original heating system had that option, but Vintage Air included a block off plate to cover the fresh air connection to the old heater.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-19-19 01:58 PM - Post#2778250
I can only hope I won't mess up this install, or if I do it won't be too serious a problem, am learning a lot, over 60 pages of instructions, it's taking awhile for me to absorb all of it, and the install of the evaporator under the dash has not been easy !!!
Had to trial fit the evap unit several times without the hard lines installed, so I could locate the mounting holes in the firewall and drill them. I had previously reworked the firewall, so "unnecessary" holes got welded up!! What fun!!
These brackets look kinda flimsy to me, but it's what they came with....
This side bolts to the bottom lip of the dash....
I needed to bolt in place the two defrost ducts that came with the unit....
Of course the holes provided did not match up, so drilled some new holes....
No problem....
Putting the hard lines on the evap unit was a bit of a horror show....
These will never match that firewall cover plate
Hmmm, can't seem to get them to look like this drawing....
After lots of messing around with them this is the best I could get...
But the unit would not go in under the dash
with these hard lines installed until I cut
the firewall access hole bigger, as you can
see above, extending the hole further down,
it was the only way I could get the unit
to go in under the dash with the hard lines
attached....
It still took some wrestling around under the dash
to get it to sort of line up in the original firewall hole....
Not the best fit, but I think I can make it work....
And I had to fab a cover plate for that larger
firewall opening I had to cut....
I think I can make this work ok,
still have a long ways to go this this though....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-21-19 06:57 PM - Post#2778470
New vents and cables came today....
The old stuff was pretty rusted up,
so I wanted new stuff....
The screws holding the old parts in are something
from way back, clutch head screws, they need
a special screwdriver, I dug around in my Dad's old
toolbox and found a screwdriver that would fit....
I got lucky....
Checking out the new vent cables and they are a bit too long,
for how I want to fit them in there....
so I'm going to shorten them to fit the way I want....
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-29-19 11:54 AM - Post#2779054
Using a new '55 Chevy Pickup dash control, it's a bit different
than the sedan control, but I think I can modify it to make it work OK !
It comes apart pretty easily,
All the old cable connections are being replaced with
electrical sliders....
The label window for the sedan version needed to be trimmed
a bit to fit into the truck control panel...
Looks good to me....
These two levers for the temp control needed to be bolted together...
This blower speed control replacement lever for the sedan version needs
to be shortened to fit this control unit from a Chevy Truck....
No problem at the knob end...
Looks good to go....
These electrical signal devices need 2" of travel and produce
a zero to five ohm signal, I think this will work just fine....
More later....
(More pix HERE if you're interested....)
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-31-19 11:08 AM - Post#2779224
Then the "mode control" lever (air flow to dash, defrost, floor)
just below the fan speed control needed to be lengthened....
And the second resistance slider (0 - 5 ohms) mounted....
Now I need to figure out how to mount the temperature control unit...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-31-19 07:18 PM - Post#2779259
Got the ac to heat temp control sliders hooked up, it looks ok....
More pix here if you want....
Sorry I didn't post more, it's been a long day and I'm tired....
-2Loose Willy
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-15-19 01:30 PM - Post#2780233
When I tried to fit the face plate for the controls in the dash opening,
the opening was just a hair too narrow, so much for the claim that
the '55 Chevy pickup unit will fit in the sedan!!!
The edges of the opening are rolled in, so with a body hammer,
I carefully "rolled" the left side edge until the face plate fit....
I got a good fit, now I find that the face plate for the truck is shorter
than the sedan, so there's an opening at the bottom....
Made an adapter plate to bolt the bottom of the face plate
into position in the dash, keeping the top located as
high up in the opening as I can....
Cut a piece of 1/4" aluminum plate, drilled it and tapped it to match
the two holes in the face plate and the two holes at the
bottom of the dash opening....
Had a box of various length of #12-24 screws, so used those....
It bolted right up and is nice and solid....
While I had the unit partially apart, painted everything that I could,
and reassembled it after everything was dry....
Everything is looking good, full function and movement on all controls....
Heat/cold controls (vertical sliders) all the way up at full cold
Now all the way down for full heat....
The upper controls, the fan is off, the air flow is at the dash....
Air flow (lower lever) at the dash outlets...
Fan (upper lever) at max....
How am I going to get this into the dash opening
It took removal of a couple of parts, some jiggling around, but I got it in....
Plugged in the control harness to the three slider units,
The controls still move nicely without hitting anything,
and the unit is mounted nice and solid....
I still have quite a bit of wiring to do before
I can put power to this unit and test it out...
Soon though....
Execution time: 0.066 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:04 AM
