 Page 12 of 12 « First<9101112
Username Post: 55 Sport Coupe - 396 LT1 - T56        (Topic#292613)
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
04-07-19 06:42 PM - Post#2763792
    In response to 2Loose
I did get a few hours to work on that clutch setup some more...
Finally located a clevis the right size to attach to a 3/8" rod and the clutch pedal...
Ran down about 3" of 3/8" fine thread so I'll have lots of adjustment available...
Looks good to me, will add another hex nut weded to the rod below the thread for a wrench...
Cut and welded an offset from 1/4" scrap to set the "push" point 2-3/4" down
from the pedal pivot, and 2-1/4" over to the left to center on the clutch MC...
Now I need to cut the rod to the correct length and round off the end to match the MC piston...
And I need to learn how to use that bore scope I just bought to check clutch gap, and figure out just where I want to put the access holes...
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
05-12-19 04:18 PM - Post#2766248
Been busy on other projects, but did get some work done on the brakes and the hydraulic clutch setup, here's a few pix:
Got the clutch pedal, clutch mc pushrod dialed in pretty well, now to see how well it really will work with this mc to activate the clutch....
The two bolts holding the offset for the pushrod on the clutch pedal was rubbing on the steering column, so I cut the heads off and welded the bolts in place, works just fine....
Also the upper hole centers the pushrod on the mc piston pretty well, so using that one...
Had to find some an-3 braided brake hose and fittings to extend the short piece I had on the slave cylinder. It ended up too long, so shortened it and changed the 90 at the mc to a 45....
Decided that before I go mounting the clutch mc in place I'd better get the brake lines installed at that mc...
The rear outlet on the proportioning valve had a weird, large thread, but one of my local auto supply houses was able to find a fitting that matched it....
Bought a few 3/16" by 60" hard lines and started fitting them to the chassis, shortening and reflaring with a double flare where necessary...
Attached the brake lines to the frame using pieces of rubber hose and clamps...
The rubber hoses at the brakes are 1980 Camaro, fit perfectly, after I moved the calipers from the rear mounting holes of the spindle mount to the front...
I think they'll be fine that way....
The passenger's side...
I still need to add some more mounting points using the rubber hose and clamps, and still need to put the rear axle hose in, again using one for a 1980 Camaro....
-Willy
More pix here
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
05-12-19 06:59 PM - Post#2766257
This is one of those threads I follow religiously. Can't wait for another, "new installment". I like the do-it-yourself, using NO pre-fabbed kits, to put this old Hawaiian 55 Chevrolet back together, into something completely new to Hawaii, and probably anywhere else. I see photos, someone has posted, of the 55, 4 door, Olds powered and blown, Gasser on other sites. Everyone is impressed. Can't wait for the first go-around-the-block ride. Keep it up Willy!
I am Butch/56sedandelivery.
Edited by 56sedandelivery on 05-15-19 08:35 AM. Reason for edit: No reason given.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
05-13-19 10:39 AM - Post#2766295
I was out driving the '55 gasser, "Patches", yesterday, still is a "gas" to drive it, love that car, the "new" TKO 600 I put in it to replace the Doug Nash 4+1 I kept breaking is not that good, shifts really hard, it feels like the synchro rings are jamming, not sliding past each other smoothly on each shift, but it is driveable, and except for the shifting, a ton of fun to drive...
Willy
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
05-13-19 03:35 PM - Post#2766310
i have never cared for the shifting of tko's
jim
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
05-14-19 10:43 AM - Post#2766381
    In response to jdk
I was thinking there was something wrong with just my TKO600 due to the hard shifting, is this a common problem?? I paid "extra" to get the trans built with the graphite (is that right?) synchro rings, not sure I have described that correctly, and I'm thinking that was a mistake, am considering pulling it apart and rebuilding with brass synchro rings. I've a lot of experience with Muncie's and my old Doug Nash, can't imagine that this TKO will be any harder to work on, and maybe I can improve it....
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
05-14-19 03:15 PM - Post#2766391
i was told those syncros helped. i never had them
in my tko. i was used to the muncie's and t10. i hated my tko and got rid of it. other people have
had the same feeling about tko. others like them.
jim
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
05-14-19 08:57 PM - Post#2766421
    In response to jdk
yup, I agree with every word!
It would be interesting for me to look inside and try to determine why!
The design of the synchro rings in the T10s and Muncies (and the Doug Nash 4+1 I still have)...
They shift great, maybe I can adapt that to this tranny??
Where's the bar....
Miss my chopped panhead, gotta get it running...
Slow Old Man=Fast Old Cars
Some Photos
2Loose Home Page
Chevys:55.Hardtop;55.4drgasser;
55.4x4truck;58.prostreettruck
+57.Olds;70.BuickGS
Avatar:Bill Stinson
Edited by 2Loose on 05-14-19 09:11 PM. Reason for edit: foggy bottom
Execution time: 0.092 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:56 AM
