Username Post: Rear Disc Brakes        (Topic#291015)
Old Chevy Soldier
Old Chevy Soldier
Loc: Central Montana
Reg: 03-12-12
12-19-12 04:12 PM - Post#2299381
I am installing a 72 Nova rearend in my 41, 2 door sedan. I have heard that the S-10 rear disc setup is a direct bolt-in swap. Do any of you have any experience with this? If it will work, I'll need to know what year S-10, 2X4 or 4X4, and if it will work with the C-Clip eliminator kit.
Life is to short to ride an ugly horse or drive a Ford
pagmanof idaho
pagmanof idaho
Loc: SE Idaho
Reg: 09-25-12
01-09-13 10:14 AM - Post#2305488
    In response to Old Chevy Soldier
I donn't know about the S10, but I found that most if not all conversions won't work unless you get the weld ons.
Current
65 Impala 2 DR SC/327 Holley Stealth FI
Past
65 Impala 2 DR SC/454
65 Chevelle 2 Dr 454 TH400
66 Nova 283 4 sp
66 Nova SS L79 4 Sp
70 Camaro SS
76 Olds 442
67 Nova Wagon
2006 Dodge Charger SRT8
pagmanof idaho
pagmanof idaho
Loc: SE Idaho
Reg: 09-25-12
01-09-13 10:14 AM - Post#2305489
I don't know about the S10, but I found that most if not all conversions won't work unless you get the weld ones that use c clip eliminators
Current
Past
66 Nova 283 4 sp
66 Nova SS L79 4 Sp
70 Camaro SS
76 Olds 442
67 Nova Wagon
Edited by pagmanof idaho on 01-09-13 10:16 AM. Reason for edit: No reason given.
Old Chevy Soldier
Old Chevy Soldier
Reg: 03-12-12
01-09-13 10:19 PM - Post#2305718
    In response to pagmanof idaho
After researching this further, I've found that the reason that most of the conversion kits don't work, is because they bolt on to the outside of the axle flange. This is also where the C-Clip eliminator bolts on. I have found a caliper bracket the bolts on to the inside of the flange. It works with rear Seville or front Monte Carlo calipers depending on whether you want parking brakes. I am still researching to find out what rotor is used. The kits come with standard rotors and I would prefer drilled and slotted. Thank You
sweet70beast
sweet70beast
Loc: United States of Idaho
Reg: 02-12-05
03-17-16 05:12 PM - Post#2616051
I used 79 Seville backing plates with 79 Firebird rotors. I used S10 front calipers because the caddy calipers were junk so I don't have the parking brake hooked up yet. All I had to do is have the axle flange turned down a tiny bit so that it would fit in the rotor hat. Everything bolted right on and I can get parts at any parts store because they are all factory parts.
70 Nova 327/T5
71 K-20 350/350/205
76 Chev C-10 350/350
80 Camaro RS V8 Factory 4spd T-tops, Tach, Tilt
72 Skylark (Suncoupe)
1 of 3943 made
Execution time: 0.139 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:41 AM
