Username Post: 350 sbc help        (Topic#290887)
73-nova-ss
73-nova-ss
Reg: 12-16-12
12-16-12 01:04 PM - Post#2298473
Hey everyone just joined this site today. Need a little help I bought a 73 nova ss last may it has a 350 with a .30 over machined crank edlebrock intake along with carb 600cfm and a th350.. I'm new to the car game it performed ok but it needs to be faster. Since I've owned it I put hooker super comp headers new exhaust new wheels cragars ss 15x8 60/275rears front 15x7 235 front. At the end of this month putting a moser 12 bolt rear in. Just wondering what I can do to the 350 to squeeze somemore horses out of it.
nickmac
nickmac
Loc: Tennessee
Reg: 02-13-07
12-16-12 05:58 PM - Post#2298532
    In response to 73-nova-ss
Welcome to CT. Headers is a good start. A better intake. It all depends on how much money you are willing to spend.
Dan
'16 Chevy Traverse 3.6 FWD
'04 Chevy K1500 Silverado 5.3 4x4
Bruisr
Bruisr
Loc: Tonopah, Az.
Reg: 04-08-05
12-16-12 07:00 PM - Post#2298559
Find out what size cam is in your 350, then you can purchase components to maximize the power of the cam, bigger carb, better intake, recurve of the timing curve, or install a better distributor. You mentioned building a rearend, what size gears are being installed? Also, look into a higher stall convertor to help put the engine in the power band for those gears.
Loud Pipes Saves Lives
1976 GMC Sprint (My sons 1st. car)
1976 El Camino (73 laguna front end)
1974 Chevelle 454 TH350 3500 stall 4.10 gear
1973 GMC sprint "DECEASED"
Bruisr
Bruisr
Loc: Tonopah, Az.
Reg: 04-08-05
12-16-12 07:02 PM - Post#2298560
    In response to Bruisr
also, when you installed the headers and exhaust did you make adjustments to the carb? Normally installing headers and good exhaust system, will cause the carb. to run leaner. You might be able to fatten it up for more power.
73-nova-ss
73-nova-ss
Reg: 12-16-12
12-17-12 10:56 AM - Post#2298700
Hey thanks for the info. I think I'll see what's up with the cam. And as for the rear I'm gonna order from moser just stuck on gears undecided on what one to go with 3.55 or 3.73,4.11s
bowtieollie
Member #3 ChevyTalk Subject Matter Expert
bowtieollie
Reg: 12-06-99
12-26-12 01:35 PM - Post#2301196
Before you go "cam crazy" - what compression is your 350???
I hope it is "at least" 11:1 with the setup you are suggesting.
Bowtieollie
Chevytalk.com Moderator
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
11-13-16 06:28 PM - Post#2661417
    In response to bowtieollie
Your bang for buck is to pull it, rebuild it, and stroke it to a 383. If you build a 383 with the same basic parts as a 350 you will gain 40 or so more hp and tq. There are several threads in the performance section of this forum. Its really not that hard, just a little more time consuming. I have built a few of them myself and they are a great engine for a street rod. Grumpyvette has several threads that are full of what is needed to get it done. The longer stroke will increase the cubic inches 33 inches along with the torque that comes with a stroker engine. If its 30 over now might have to bore it to 40 which will make it a 385. 425-450 hp is common with that cubic inch engine.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2017 Harley Davidson XL1200 Sportster
2018 Nissan Versa Note
Edited by busterrm on 11-13-16 06:57 PM. Reason for edit: No reason given.
Execution time: 0.183 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:10 AM
