Username Post: Corvette Generations: C4        (Topic#288490)
10-18-12 11:32 AM - Post#2280841
lynper
Gold Supporting Member
Loc: Norway
Reg: 11-08-05
09-15-16 08:47 AM - Post#2651476
    In response to lynper
Aircondition: Had a nice cruising today, but when I had a "pitstop", the aircondition would not shut down. Tried different "modes", ond also to shut it off while the engine was running. Had to start and drive home (to avoid a flat battery). When at home, I had to disconnect the battery to shut down (may be only the fan). When connected the battery again after an houer, the blowing of air started again. Seems like a stuck relay??
Norwegian retired airline-pilot
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-15-16 03:08 PM - Post#2651541
https://www.youtube.com/watch?v=lWIrT8tN-a8
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
lynper
Loc: Norway
Reg: 11-08-05
09-16-16 09:16 AM - Post#2651669
    In response to TAT_2
Thank you for feedback. Nice to know!
But, the green light does not start flashing, and there are no failure code.
TAT_2
TAT_2
Reg: 10-29-00
09-16-16 11:17 PM - Post#2651754
http://www.corvetteactioncenter.com/forums/c4-tech...
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
lynper
Loc: Norway
Reg: 11-08-05
09-20-16 09:44 AM - Post#2652356
Thanks! May be a litle closer to solve... Have recogniced the black and pink wires..., but where is the stuck relay?? My "Haynes repair manual" does not show the location.
TAT_2
TAT_2
Reg: 10-29-00
09-21-16 04:22 PM - Post#2652574
I DONT BELIEVE THE 94 HAS A BLOWER MOTOR RELAY,THAY CHANGED THE CLIMATE CONTROL & THAY USE A TRANSISTORIZED FAN CONTROL RESISTOR,FOR SOME REASON WHEN THAT FAILS THE FAN STAYS ON ALL THE TIME EVEN WITH THE IGN OFF.I HAVE THE BASIC KNOWLEDGE OF DIFFERENT SYSTEMS ETC,BUT HAVENT GOTEN INTO IT ON A 94.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
lynper
Loc: Norway
Reg: 11-08-05
09-22-16 04:08 AM - Post#2652615
Thanks! I guess the error is in the control module.
TAT_2
TAT_2
Reg: 10-29-00
09-22-16 05:38 AM - Post#2652619
EVERYTHING IS LEADING TO THAT BEING BAD,A LINK TO WHAT IT LOOKS LIKE.
http://www.ebay.com/itm/like/301731936775 ?lpid=82&...
THAT SHOWS BOTH SIDES
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
lynper
Loc: Norway
Reg: 11-08-05
09-29-16 08:46 AM - Post#2653999
Thank you! I have found, and bought one from ebay ($50 + shipment)Waiting..., and I hope the control module will solve the problem. Until then.., I have just unpluged the connector from the module to the fan-motor. No problem, it is not very hot here in Norway (Tonsberg)in sept.
TAT_2
TAT_2
Reg: 10-29-00
09-29-16 02:57 PM - Post#2654046
YOUR WELCOME
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
lynper
Loc: Norway
Reg: 11-08-05
10-14-16 08:22 AM - Post#2656493
I have received, and installed another control module. (The used part bought on ebay: 50USD + shipment+norwegian taxes ended at a price of 110USD!) But now the A/C seams to be operating just fine.
TAT_2
TAT_2
Reg: 10-29-00
10-14-16 04:33 PM - Post#2656550
GLAD IT WORKED OUT FOR YA
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:40 AM
